New flooring
Discussion in 'Roof/Floor Repair & Maintenance' started by Ralpert, Jun 25, 2013.
  1. Ralpert
    Ralpert New Member
    31
    Jun 18, 2012
    The original vinyl flooring is getting kind of nasty. I have a bunch of extra laminate flooring. Any reason why I shouldn't use it in the pup?
  2. Raycfe
    17,005
    2,575
    As long as it doesn't get abnormally wet, I think it would be fine.
  3. Dubbya
    6,130
    67
    Aug 2, 2011
    Steinbach, MB
    It's been done, so there's no real reason not to go ahead and try it. You've already got it, so it's not like you'll have to drop any extra cash on it. Like Ray said, just don't let it get too wet.
    I'd definitely look into gluing it down though. Talk to someone in a flooring store to see what they recommend.
  4. 3sons
    3sons Only good at Drinking Beer
    119
    Jul 18, 2012
    I recently put the peel and stick tiles in my coachmen clipper. I have been on two trips now with it and it has not came up or anyting. If you want to see some pictures of mine search coachmen clipper new floor.Good luck and happy camping!!
  5. vagov
    vagov Well-Known Member
    4,432
    553
    Aug 13, 2012
    Pittsburgh, Pa
    i got a extra peice of vinal flooring from my kitchen just wondering if i could glue down on old existing just thinking it may be alittle thick in the doorway.
  6. kitphantom
    12,277
    1,272
    We put peel and stick vinyl over the old flooring in our previous pup. We were able to slide it under the edge of the benches, and did not have to worry about cupboard door clearances, since we did not reinstall doors at renovation. We scrubbed the old vinyl very well before installing the new. It stayed pretty well over the 2 seasons we used it, though we had one place that tile just did not stay put. It was under the table, so out of the way.
    As has been said, some people have put laminate in, but you will need to check clearances with your specific laminate, for any cupboard doors. In our current pup, we have an issue clearing a throw rug with one door, I would imagine laminate flooring would be the same.
    It seems to have worked for some, but YMMV. Most pups are exposed to a wide variety of temperatures and humidity levels, not to mention the bumps and vibrations of driving to and from campgrounds, so any flooring gets more stress (not counting foot traffic) than installed in a home.
