New leaf springs
Discussion in 'Tires / Brakes / Bearings / Axles' started by D&JColorado, Jun 4, 2020.
  1. D&JColorado
    D&JColorado New Member
    May 5, 2020
    I recently purchased a 1995 Coleman Utah and was wondering if I should look at replacing the leaf springs. I want to run a larger tire and switch to radial tires for a longer road trip ( 2500 miles)we are going to make. Any advice or info would be greatly appreciated
  2. Matt Benoit
    Matt Benoit Well-Known Member
    544
    335
    Jul 30, 2017
    Warren, MI
    I would suggest the spring over axle conversion if you're looking for a lift. Custom springs could achieve the same result tho
  3. D&JColorado
    May 5, 2020
    I thought of that but I am not sure I want that much lift. I thought about new leaf springs and a shackle link. Thanks for the input. I appreciate it.
  4. Raycfe
    17,005
    2,587
    The wheel well is only so wide (side to side) and (front to Back). You should have slipper springs.
    I would also suggest forget the spring idea and just relocate the axle to underneath the spring. You will have to add spring seats to the axle ... not hard..... And the axle is bowed so you just can't flip it upside down. The axle and the brakes have to stay just as they are .... just remount it under the spring.
  5. Sjm9911
    7,368
    4,751
    Of the springs aren't bad, just replace the tires and make sure the hubs are greased. I never had a problem on my 2000 westlake , and it went a bunch of places. Unless you need ( dirt roads) or really want the bigger tires and lift, why bother with it?
  6. D&JColorado
    May 5, 2020
    I really don't think I'm going to do anything at this point it's a long road trip but the tires on it are really good they're just small there's a lot of controversy over bias or radial tires but I think I'll be fine just leaving it alone
  7. Sjm9911
    7,368
    4,751
    I think radials are better myself, dont heat up as much . But more then that is the date codes on the side. Check those. If say over 7 years replace them. Some say 5.
  8. D&JColorado
    May 5, 2020
    Tires are E rated Carlisle sport trail less than 3 yrs old.
  9. xxxapache
    3,351
    1,340
    Unless the springs are flat or a leaf was broken, I would leave them alone.
    My oldest trailer is a 1976. I have probably overloaded it a time or two. The springs are still good.
  10. Anthony Hitchings
    1,547
    802
    Mar 2, 2019
    The springs are good until they break. I looked over my springs when I took everything apart for the SOA conversion (and replaced all shackles, bushings, bolts etc). Over 1,000 miles later, the left spring broke - brittle fracture. We had never overloaded the Aliner.
  11. D&JColorado
    May 5, 2020
    Thanks for all the help. I appreciate the information.
