New member, old camper...
Discussion in 'Introduce Yourself' started by NHcamper, Oct 13, 2019.
Tags:
  1. NHcamper
    NHcamper New Member
    Oct 13, 2019
    Southern NH
    Hi,
    My husband and I have owned a (don’t laugh) 2001 Starcraft Galaxy pop up for years. We got it when the kids were younger. Lots of camping in New England area. It’s always been a faithful friend, no major issues.
    It didn’t get opened last summer, now won’t crank up. No cranking noise, just frozen. Won’t budge.
    He wants to ditch the old thing, but I’m way too Scottish to not try to fix it!
    We’ve lubed everything with wd40. Nothing appears to be broken, no visible problems.
    Anybody know the first thing to check?
    Thanks!
    NHcamper
  2. WrkrBee
    WrkrBee Well-Known Member
    2,489
    953
    Welcome to the Portal from South Carolina. Someone will be by to help. Nothing like that on an Aliner.
  3. Raycfe
    15,238
    1,449
  4. kcsa75
    kcsa75 Well-Known Member
    2,951
    1,351
    Sep 9, 2013
    Kansas City
    Welcome to the forum from Midway USA.
    If the crank won't even turn, I'd start at the winch/wiffle tree. Sounds like something my be lodged in the works.
  5. bobinfleet
    bobinfleet Active Member
    431
    172
    Sep 2, 2011
    Hampshire UK
    Hello and welcome from Hampshire UK[GBR], 2001, that's not old[:D]
  6. FARfetched
    FARfetched Active Member
    404
    167
    Nov 22, 2018
    Sector 706, Planet Georgia
    Welcome from Planet Georgia!
    My Starflyer is also 2001, so it's probably the same mechanism. Check the easy stuff first: are the roof latches undone? What happens if you turn the crank left to bring it down a little farther before going up?
    Assuming none of those are the issue, go underneath and hit the winch with some silicone lube — every touchy-movey part except the brake, for obvious reasons. Look at the pulleys, make sure none of the cables have jumped, and hit them with some lube as well.
    J Starsky and HappyTraveler like this.
  7. BikeNFish
    BikeNFish Well-Known Member
    2,906
    1,811
    Apr 24, 2017
    Maplewood, MN
  8. PopUpSteve
    PopUpSteve Administrator
    18,907
    1,642
    Dec 22, 2002
    Malvern, PA
    Welcome to PopUpPortal
  9. J Starsky
    J Starsky Well-Known Member
    749
    533
    Aug 3, 2017
    East Central MN
    It is amazing how a lawn mower can be parked and the belts can freeze to the pullies, then they end up at my house because they "wont fire, won't turn over" because of a stuck belt. My 1984 hates sitting too long unused, try lifting the roof a bit, then back down just by hand. Try to free those cables a bit. Probably the whiffle is stuck or frozen, but it should be temporary for you~!
  10. nineoaks2004
    7,308
    3,045
    Dukes, Fl
    Welcome from Dukes Fl Good luck and happy camping
