New pop up owers, water hearted question
Discussion in 'Introduce Yourself' started by Chris Baker, Oct 17, 2021.
  1. Chris Baker
    Chris Baker New Member
    Oct 17, 2021
    My fiancé and I recently bought and are learning our 98 Coleman fleetwood grandview sp. can’t seem to get the water heater to work on electricity or LP, I can get flame on the pilot, but won’t stay lit for long….any suggestions? Thanks
    Chris and Kim
  2. WrkrBee
    WrkrBee Un-Supported Member
    6,538
    3,448
    Welcome to the Portal from South Carolina. Cut the propane valve off for a couple of minutes and let the safety valve reset. Then open the valve slow. Slowly pressurize the gas line. Then try to light the water heater again.
    Our water heater has 120vac switches inside the camper and in the water heater compartment. Both have to be on to heat water with electric.
  3. Chris Baker
    Oct 17, 2021
    I tried that, but no go. The flame stays on for a few minutes intermittently, then goes out, but the compartment next door, where the furnace is, stays on. I get hot water for a second then it goes right back to cold. I never noticed the switch before so I’ll give that a try and get back to you. Thank you.
  4. Raycfe
    17,754
    3,248
    First off download the manual for your water heater form the web. Decode the model number and you will know how your water heater operates. Some are all manual, some are self igniting gas and some also have an electric heater. Thats where I would start.
    kcsa75 likes this.
  5. Chris Baker
    Oct 17, 2021
    I’m on it. I have the manuals for everything else it seems, but no H2O heater, so I’ll start searching and being there. Was hoping to find a few other owners of my particular model on here to share any secrets of operations (as a whole), because some of these manuals don’t give you every detail or in/and out you’d like to know. It’s a new world for us, we’re excited but a bit clueless in our first few trips. We’ll keep reading as much as we find until it’s 2nd nature. Thanks guys and gals.
  6. LilRed
    LilRed Well-Known Member
    679
    326
    Jan 9, 2021
    Long Island NY
    Welcome from NY. Best to you in your new adventures!
  7. Sjm9911
    10,626
    8,008
    Usally when the flame dosen't stay lit, i replace the thermocouple first. Its probably like 15 bucks. I had a 2000 coleman, mine did not have an electric mode. It was gas only and had to be lit outside, take a picture of it so we can see what your working with. If it has a electric mode it may not be original. And you have to make sure its full of water , so make sure it isnt bypassed.
  8. jmkay1
    6,968
    4,014
    Just throwing this out there as bugs sometimes like to make nests in the propane lines. It's possible there may be enough gas flow to light but not enough to sustain.
  9. Sneezer
    2,856
    1,690
    The pilot needs to heat the thermocouple sensor sufficiently before it will stay lit. On mine I have to keep the pilot engaged for a couple minutes before it will register and call for full gas. Once that happens you are usually good, and the pilot should stay lit after the water reaches temp. Make sure the heater is full too - you don't want to be warming an empty tank.
