BoomJammer
Jason
- May 17, 2012
- 217
I had bearings packed and new tires put on at a local tire store that had been referred to me by the local RV store. The old tires had a sidewall pressure rating of 65 psi. The new tires have a pressure rating of 50 psi. When I got home and saw this difference, I got concerned.
The "Tire and Loading Information" sticker on the camper says the tires should be ST185/80D13D, inflated to 65 PSI. The GVWR is 3450. The GAWR is 3300.
The old tires said "8 ply" and were bias ply tires. I believe that means they were D rated tires, as they should be per the ST185/80D13D designation, right?
The new tires are
Did they give me the wrong tires for my trailer? It's ok to use radial tires, isn't it? But shouldn't even the radial tires use the same load rating (D) as the original bias tires?
I went to the Towmax website. It appears that they don't have a D rated tire in the 13" size that I need.
I went to the etrailer website. They don't have ST185/80 13" radial D rated tires. Only bias ply tires. The only 13" D-rated radial tires that they have are ST175/80R13.
Should I return these tires and insist on Load Rated D tires? ...and be satisfied if the only option is bias ply? From my limited knowledge of tires, that seems like my best option, but I am open to suggestions.
The new tires are
- Power King Towmax STR Radial Tires
- ST185/80R13
- LR C
- 6 PR
- Tread 3 plies: 1 polyester + 2 steel
- Sidewall 1 ply polyester
- DOT ADB7 GPB 3514
- MAX Load single 670 KG (1480 lbs) at 850 KPa (50 psi)
