New stereo install with pics
Discussion in 'Campsite Electronics' started by Freedom72, Jul 11, 2010.
  1. jjsul
    jjsul New Member
    195
    Aug 17, 2010
    I'm doing a stereo over winter. Any suggestions on antenna location/mounts?
    thanks
    Jerry
  2. Bullfrog Bheer
    Bullfrog Bheer Active Member
    2,870
    Feb 19, 2010
    Central Wisconsin
    I was wondering about the antenna myself.
  3. JayAmyJamy
    JayAmyJamy New Member
    175
    Mar 30, 2009
    I mounted mine to the frame, just behind the propane tank. That is about as far as the original cord and an extender would go.
  4. GetOutSide
    GetOutSide Let's go get lost...
    460
    Oct 25, 2010
    Fleetwood / Coleman has theirs looped in a circle about a foot wide under the counter... [::)]
    I was putting in an on/off switch for my stereo and saw the speakers were labeled "front" and "back" so I finally figured out the fader: press the volume button.
  5. marshall
    marshall New Member
    Apr 29, 2009
    I am thinking of installing a radio inside my pup. How would I hook the radio up to my converter to power it?
  6. Raycfe
    15,413
    1,576
    Powering a radio is simple, just tap a 12 volt source near your radio location. Most radios will have 2 power leads, one to retain the stations/clock and the other the radio itself. You can just put these two together, you will loose the stations when the battery is disconnected and the PUP is unplugged. You will also need to tap into a ground wire. We use an car antenna with a "booster" coil on the mast and is mounted sideways under a counter top, seems to work well. Now my 2 cents; you should think about how easy it will be to operate the radio inside the PUP. Mounting it low on the face of cabinet it may be hard to see and control. Our PO installed a very nice AM/FM/CD which had buttons so small the radio was a pain to operate. This last summer it replaced it with a 2 knob radio and it is much better. A small boom box on the counter would be even easier, but the hole was already there. So I am suggesting you plan your radio install thoroughly before you cut some holes. Also you do not need much to fill up a PUP with music, and at campground quiet time it has to be on low.
  7. marshall
    marshall New Member
    Apr 29, 2009
    So if I understand correctly just splice the radio power wires directly to say an electrical outlet?
  8. themanfromvan
    themanfromvan Van, PA - Near The PA Wilds
    2,109
    51
    Jul 31, 2004
    Van, Pennsylvania
    No, if it's a car stereo it's 12V. Crawl under your PUP and look for 12V wires and tap into those. Don't be wiring it into the 12/2 wire for your 110 volt appliances.
  9. marshall
    marshall New Member
    Apr 29, 2009
    So what would 12V wires be, like a interior light. Come to think of it there is a "cigarette lighter" type plug that the previous owners added I could just tap into that.
  10. Raycfe
    15,413
    1,576
    The lighter will be perfect.
  11. DSCinVegas
    DSCinVegas New Member
    627
    Sep 16, 2010
    Hi all--- I don't think that I could figure this out on my own.. definitely missed the Electrical boat when it sailed here. lol. Just curious if anyone has taken their PUP into a service center to have one installed and if you ---& if you did what was the approx. fee you paid? We have Camping World & Bass Pro Shops here in town that could do it I think. Best Buy might even do it-- although I might get a laugh or two taking it in and setting it up in their service center!
  12. JayAmyJamy
    175
    Mar 30, 2009
    Don't waste your'e money on that.
    As folks directed before you can splice directly into a 12v source. Or you can do what I did. I simply run the power wire straight to the battery (which is EXACTLY how your car radio is juiced). Red power goes to the red terminal, black ground goes to the black terminal. Run an antenna and mount it (I mounted mine on the a frame running the wire underneath th pup-using an extension).
    It's really a lot easier than it sounds.
  13. DSCinVegas
    627
    Sep 16, 2010
    Thanks JAJ--- maybe this (is) something that I could do on my own, I have yet to hook up to power at a CG so the direct to 12v might be the way to go. Currently I use an XM boombox that stays on my dinette table while camping-- I run a heavy duty power cord out thru the canvas to a converter I have plugged into one of my Jeep's 12v outlets. Fairly easy fix, but not having to deal with one more thing to load out/in would be great!
    By the way, does your sound system draw a significant amount of power from your onboard battery?
  14. Techhead
    Techhead New Member
    121
    Sep 21, 2010
    A car stereo has to go through a fused circuit first.
    On a PUP, if you run the head unit direct to your battery, put an in-line fuse large enough to support it.
    Freedom72,
    Nice clean install BTW. [:D] But why would you only install one speaker inside? I personally would put two at least then you would get your music in stereo. [;)]
  15. JayAmyJamy
    175
    Mar 30, 2009
    DSCinVegas,
    By nature car stereos don't draw much power. You should be able to run it for a while before it drains the batter; and by while I mean 24/7 for days. It prolly draws as much as the camper's dome light.
    Also, these days, radios come with their own fuse. You don't need to instal an inline fuse at all. If you were installing a powerful amplifier, then maybe. The pup doesn't have all kinds of other stuff drawing from the battery like a car does; which is why the car needs an alternator.
    Just keep extra fuses handy for the radio just in case you blow one because you hooked the ground to the power by mistake. [:O] [;)]
  16. Xolthrax
    Xolthrax Franconia, Pa.
    4,648
    Mar 17, 2007
    Franconia, Pa. Butter capital of the East
    I'd like to weigh in on this subject again.
    First, given that your camper is a 1992 model, it is almost certain that the output from your converte is unfiltered. It will eventually kill a modern electronic appliance like a car stereo in short order.
    Your alternative to that is to wire it directly to the battery as JayAmyJamy suggested. I used to do that myself. The downside to that is that if you are camping in a site with electic, you still need to rely on your battery for the stereo. It's not necessarily such an insignificant power draw as DSAin Vegas has suggested. Maybe, maybe not. It depends upon your use. If you have a high power amplifier, it will drain your batery more quickly.
  17. GetOutSide
    460
    Oct 25, 2010
    I'm with X on the drain... 35 to 50 watts is average for a basic car stereo, or roughly 3 - 5 amps. I'll let you know exactly what the stock Coleman is as soon as I get my new solar charge controller, as it can accurately monitor any current draw.
