New tire goes BOOM!
Discussion in 'Tires / Brakes / Bearings / Axles' started by Andy G., Aug 11, 2019.
  1. Andy G.
    Andy G. Member
    53
    34
    Sep 2, 2017
    WI
    After a nice weekend of camping, we were returning home when we had a blowout on the brand new driver's side pup tire. Pulled over to change it, but discovered the spare wouldn't fit, even though it was THE SAME SIZE AND MANUFACTURER! The spare tire was considerably taller & wouldn't fit in the wheel well. Fortunately, we were only 25 miles from home, so we unhitched, and left the pup by the side of the highway. Went home and retrieved one of the older tires I had removed this spring. Got it changed & headed home. Guess I'm done with Carlyle tires.
  2. Annunzi
    Annunzi Member
    42
    Jun 14, 2019
    Vancouver Island, British Columbia
    That seems strange? Are you sure the spare tire and the wheel were the exact same size as the one you replaced? Wheel diameter, aspect ratio and width? Also the wheel width and offset? I know on our car, because there was so little wheel well clearance, even the slightest difference in size meant the tire wouldn't fit.
    Andy G. likes this.
  3. tombiasi
    5,373
    1,004
    If you bought two of those new tires you would be well served to inspect the other one carefully.
    This condition is not limited to one brand of tire.
    I have owned Carlisle tires and have had no problems. Had that problem with Kenda once but I still buy Kenda tires.
    theseus and Andy G. like this.
  4. Andy G.
    Andy G. Member
    53
    34
    Sep 2, 2017
    WI
    Thanks folks. Yes, two new Carlisle 5.3x12 wheels with tires already mounted. Both new stock, made in 2018. The spare is also a Carlisle 5.3x12 but was there when I bought the PUP. It looks to be unused, so I kept it. One would certainly assume these should be an exact match, but they aren't. I will contact Carlisle for guidance on this.
  5. joet
    4,766
    961
    Something wrong since both are the same size and brand????
  6. Andy G.
    Andy G. Member
    53
    34
    Sep 2, 2017
    WI
    Definitely something was wrong. I'm thinking the tire was mislabeled.
  7. Sneezer
    1,547
    543
    Was one bias ply and the other radial?
    On mine a fully inflated spare won't slide between the camper frames without some serious finagling.
  8. theseus
    theseus Centerville, OH
    2,869
    418
    Feb 6, 2007
    Centerville, OH
    My question is what was the load rating? I’m guessing it was a B. You should move up a letter. Higher load rated tires will cost more, but in my experience, are good insurance against possible overloading and blow outs.
    tombiasi likes this.
  9. Andy G.
    Andy G. Member
    53
    34
    Sep 2, 2017
    WI
    Thanks everyone. Both running tires were bias, both C-rated for load. They were a new matched pair, installed over the winter while in storage. I'm starting to think I just ran over something and blew the tire. Seems the most logical explanation. As for the weird-sized spare (C-rated also) that was on the camper when I bought it, it was in good shape, so I kept it. I have no explanation for the size difference.
    Andy
  10. wmgeorge
    wmgeorge Member
    81
    21
    Sep 6, 2019
    Ok define won't fit. You mean the spare had 4 holes and the new tires had 5, which is hard to believe. Or they both had 5 holes but they had different hole spacing or one tire was larger or smaller in diameter than the other??? a 5:30 x 12 is a 5:30 x 12 no matter where you purchase. How much pressure did the tire that blew out have in it and did you check the other one?
    Was your spare a radial by chance?
  11. Andy G.
    Andy G. Member
    53
    34
    Sep 2, 2017
    WI
    Both tires were 4-hole, same marked size and rating. The spare was physically larger in diameter and wouldn't fit into the wheel well. Both tires had 80psi, and both bias ply. Very strange.
  12. wmgeorge
    wmgeorge Member
    81
    21
    Sep 6, 2019
    You need to look closer at the tire size imprinted in the tire rubber something is not the same. Are those tires marked for 80 psi? Most are only 65. Nope online shows 80 psi. Load range C 1025 lbs?
  13. BillyMc
    BillyMc Well-Known Member
    1,218
    577
    Mar 25, 2018
    Strange indeed! The size is actually molded with the tire, so I can wrap my head around how this could happen. Looking them up a 5.30x12 has a 21.9" diameter. I just measured mine with a tape measure and they are more like 21.5". Three tires two brands and the spare is new never bolted to anything but the spare tire mount.
