New to us Coleman Yukon!!
Discussion in 'Camper Restoration Projects' started by cruz2017, Apr 6, 2017.
  1. Sotovoce
    Sotovoce Active Member
    260
    143
    Jun 27, 2015
    Georgia
    What a transformation! When you finish this project you need to stage the camper, make high quality photos and submit your story to the Popup Princess.
    cruz2017 and KWAZ like this.
  2. cruz2017
    cruz2017 Member
    32
    25
    Feb 27, 2017
    Ohio
    Sorry I totally forgot to take pictures!! Oops. Well you get that paint in the picture. Put a good heavy base layer down. Then a hefty second coat once your second coat is on you lightly and evenly blow.... that's key. Gently blow the garage floor chips onto the wet paint. Once that's dry I put a ton of poly clear coat on top. I did a ton of top coats of clear coat.
  3. cruz2017
    cruz2017 Member
    32
    25
    Feb 27, 2017
    Ohio
    So I'm adding this picture beceause I have had to redo my abs plastic fix on my roof multiple times in different locations. Lots of posts about fixing your abs roof but I never found a good post. This is a quick picture of how to actually grind out your crack. The wide crack is what you want about to grinding disks wide. The bottom cut is only one pass with a grinding wheel. I only grinder out the crack with a single pass with the blade the first time. Make sure you make it wide enough that you can get the MEK onto the edges on both sides and it's wide enough that you can actually get the melted plastic into the gap and completely fill the void. Let's hope this is the last time. Very frustrating.
  4. Fordiesel250
    Fordiesel250 Member
    571
    22
    Mar 28, 2010
    Great job!
  5. roadrat
    roadrat New Member
    Aug 9, 2017
    Was any of your paper peeling on the cabinets? If so how did you deal with this?
  6. DFire2
    DFire2 Active Member
    260
    56
    Jun 18, 2016
    Central Michigan
    I like that wrap around seating! My popup had a U-shaped seating like that as well, but after remodel, we limited the seating and added storage (no front storage compartment on mine). I just finished making and installing cabinets as well. Love the outcome, check it out in my signature.
    Keep up the good work. I know most people with ABS roof have eventually just replaced the entire roof itself. That's my plan for next year (though mine is not ABS, but rotting)
  7. Jesse Ramos
    Jesse Ramos New Member
    17
    Aug 21, 2018
    Racine, WI
    This is bad ass, i have the same camper and am ready to get started on the remodel! any recommendations of anything i can use to help support the roof before it cracks? some pre maintenance perhaps?
