newbie here! Jayco King1986
Discussion in 'Introduce Yourself' started by firemom, Mar 19, 2015.
  1. firemom
    firemom New Member
    30
    Dec 26, 2014
    My mom and I are fixing up a Jayco and as I was working on it We found an awning and screened porch. We have some poles. I can't seem to find instructions on putting it up.
  2. kyar326
    kyar326 New Member
    70
    Feb 20, 2015
    Is the awning attached to the roof, or is it a separate awning?
  3. Raycfe
    15,254
    1,453
    [{:)] Welcome from southeast Connecticut. Happy and safe camping. Glad you stopped by PopUp Portal. [CP]
  4. betancourtfamily6
    betancourtfamily6 New Member
    200
    Feb 26, 2015
    Hi and welcome.. We have a 1987 Jayco JayKing 6 Deluxe.. I double checked our manual and of course there isn't anything in there about awnings.
    We bought ours about 1 month ago.. love it.. but yet to take the awning out of its bag.
  5. betancourtfamily6
    200
    Feb 26, 2015
    however I do believe I did see a channel on the outside roof which I'm assuming is for the awning.. may be the same on your 86
  6. jman1200
    jman1200 http://i529.photobucket.com/albums/dd340/jmanotas/
    1,261
    Nov 11, 2013
    Welcome from Southwestern Ontario !
    I've seen different types so not sure if this applies, the spring loaded posts go between the roof and the edge of the awning, the adjustable ones (you need to rotate one pole while holding the other one and then extend it) go vertical on the edge of the awning.
    Once the awning is up, lay the screen on the floor, you should have two sides and the front portion, some also come with a skirt that covers the bottom open portion of the trailer.
  7. JeffC
    JeffC New Member
    1,087
    Nov 30, 2014
    Welcome and if you get it set up don't let the wind put a pole in your roof!
  8. firemom
    firemom New Member
    30
    Dec 26, 2014
    https://www.dropbox.com/s/e8q8tv7bejs0l05/2015-03-22%2016.19.53.jpg?dl=0
    https://www.dropbox.com/s/r93yzfdhjxt5729/2015-03-22%2016.20.06.jpg?dl=0
    Got it!
  9. firemom
    firemom New Member
    30
    Dec 26, 2014
    [​IMG] I even got the table up!
  10. firemom
    firemom New Member
    30
    Dec 26, 2014
  11. gmajane
    gmajane New Member
    Jan 5, 2015
    My job is to make the cushion covers and eventually curtains. We have the fabrics from a thrift store in greens and blues. I think it will turn out well. Later I will figure out how to use drop box and show the fabrics. I'd like to paint the cabinets, but that won't likely happen this season. (Theresa/firemom's mother)
  12. firemom
    firemom New Member
    30
    Dec 26, 2014
  13. firemom
    firemom New Member
    30
    Dec 26, 2014
    Step one on rebuild. Door.
  14. kyar326
    kyar326 New Member
    70
    Feb 20, 2015
    Firemom - How has your PU come along?
