Newbie looking for a pop camper under 1,000 lbs
Discussion in 'Introduce Yourself' started by smatyki1, Jun 21, 2016.
  1. smatyki1
    smatyki1 New Member
    Jun 21, 2016
    My 2016 Nissan Rogue will only tow 1,000 lbs. I am looking for a lightweight pop up that sleeps 3 to 4. Is this possible? thanks in advance!
  2. jmkay1
    7,074
    4,137
    You may want to look into the living light quick silver campers. They are considerably more money new, but are on the lighter side. With your tow limitations, you will be cutting it close even with those units and you will be looking into the more bare bones units. I'm thinking an 8' barebones popup may work.
  3. tfischer
    4,751
    2,358
    May 21, 2014
    1000 pounds is incredibly small towing capacity... even the smallest Quicksilver has a dry weight of 750 ponds and a GVWR of 1200 pounds: https://www.livinlite.com/6.0-overview.php
    And for all practical purposes it only sleeps two.
    Remember that dry weight will not cover propane tanks or batteries or water or anything else that you might want to take along with you. It's also likely that the 1000 pound rating of your vehicle assumes little are no cargo in the back of your TV, and only one or two passengers.
  4. edh
    edh Active Member
    1,072
    Jun 2, 2008
    Might want to look at teardrops instead, that plus a tent for the kids.
  5. Nandy
    Nandy Active Member
    2,255
    22
    Mar 29, 2010
    Your options are very limited and you will have to do compromises. With that towing capacity I think all you will have left is a very small camper and tents. I doubt you will find anything that will sleep 4 and once it is all loaded it will be under 800 lbs since you should ideally have a 20% reserved tow capacity. Some will just get a vehicle just for towing and since it will be used so little you dont need one with all the whistles and bells none it need to be last year model.
    good luck.
  6. kitphantom
    13,298
    2,414
    Some of the older campers that are basically tents on wheels will probably come under your weight limit. You'll need to watch how much you pack and things like LP tanks.
    Our first pup was tiny, under 800#, but only had one bunk end and a 6' box. It got snug for two people, let alone 3 or 4. That was a 1984 Palomino Shetland, which was also made with two bunks. Haybale's "new" 1973 pup is one of the vintage, bare bones, tents on wheels (his has a slide out "kitchen"): http://www.popupportal.com/index.php?topic=101797.msg1034107#msg1034107
    One thing to do is to make a list of what you think that you need and want, as well as to assess what the towing capacity means - is that separate from the load the vehicle is carrying, do passengers need to be subtracted from the load capacity, etc.
    Have you camped before? do you have equipment that you can use in addition to a bare bones pup to camp until you have a heftier tow vehicle?
    neighbormike likes this.
  7. Wandering Roo
    Wandering Roo New Member
    Jun 16, 2016
    I think the quicksilver 8 should work for you as long as you didn't pack too much. It will have a bed on both ends and a dinette that converts to a bed as well.
  8. tfischer
    4,751
    2,358
    May 21, 2014
    1127 pounds dry weight, no way.
  9. edh
    edh Active Member
    1,072
    Jun 2, 2008
    If you are ambitious another option might be to build your own "foamie" camper, ie one where the sides and roof are made of 2" closed cell foam; Google it and you'll see a fair amount about them in the world of teardrop campers. Even then you'd need to start with a very light chassis, probably aluminum. The foam is surprisingly sturdy when properly constructed, and if anybody scoffs you can point out how well their canvas will work at keeping the bears out of the larder.
    Might be simpler to wait a bit until you can trade up to a TV with more towing capacity. Even 1500lbs will make for many more choices, but aim for at least 3000lbs when the time comes, and if going with an SUV, get the V6 tow package (most times that will be your only choice). If you foresee owning a TT or hybrid, you'll need at least 5-6000 lb capacity.
  10. Halford
    Halford Well-Known Member
    3,563
    571
    Sep 28, 2011
    Santa Clarita, California
    If it is possible, buy a TV that has capability to tow up to 5000 lbs.. that you can have wider selection of popups for greater popup experience.
  11. tfischer
    4,751
    2,358
    May 21, 2014
    LOL. Even the huge highwall I was checking out on Craigslist today (not seriously looking, my vehicle can barely pull the one I got) was only 3750 GVWR.
    But I doubt the OP really wants to buy a new TV since they already have a new vehicle.
  12. Miamomof8
    Miamomof8 Member
    81
    Feb 16, 2016
    Our '92 Palomino Pinto is 995 lbs. It sleeps six but we cram in seven (2 adults and 5 kids).
  13. edh
    edh Active Member
    1,072
    Jun 2, 2008
    The 5000 spec listed was because once you go above a 3000-3500 lb tow rating, the next higher option is usually 5000 or 6000; leastways I don't recall many 4000 lb ratings. And if you want to load a 3500lb camper and then tow at 20% below your max rating as some prefer, you're looking at a 5000lb minimum tow rating.
  14. mickaqua
    mickaqua Member
    680
    25
    Aug 3, 2012
    Any 5' x 10' utility trailer with a wood floor + 4 screw type stabilizer jacks + Coleman tent(9 x 5) = success [CP]
    jifjifjif, xxxapache and Flamingo Guy like this.
  15. Sean Hayes
    Sean Hayes New Member
    Feb 26, 2019
    Check to see if your vehicle is a CVT transmission if it is, in no way ever tow with it. CVT transmissions are not clutch and disk driven they are a ball and roller that switches pivot points using the fluid itself to provide grip between them. If you try to over pressure it you will wear it out first tow. If it's a regular transmission adding a trans cooler usually allows another 500lbs of towing.
  16. WrkrBee
    WrkrBee Un-Supported Member
    6,569
    3,461
    It's an old thread from June 21, 2016. Original poster lasted 8 days on the Portal and hasn't been back since.
