NEWBIE TO EXTERIOR PAINTING-NEEDS GUIDANCE
Discussion in 'Camper Restoration Projects' started by tgau16, Jan 31, 2018.
  1. tgau16
    tgau16 New Member
    28
    Mar 2, 2016
    RSM CA
    Hello,
    There's a lot of information out there for me to look at and I have used much of it. However I'm nervous to start the next step and I just want someones opinion/advice on how to proceed.
    1981 Starcraft Venture.
    I'm starting with the back panel because it's the easiest to get to in the garage. It's textured. I've taken all the decals off. And the gross silicone sealant. In the areas that I've taken off the decals, I am down to the bare metal. The rest of it is paint. Next step:
    Sand? I read that I shouldn't sand textured areas.
    Clean it? With what? Soap and water, all purpose cleaner, thinner, etc.?
    Primer? Rustoleum? Auto? Oil? I wouls prefer easiest and least messy.
    Paintable sealant after priming, before painting correct?
    Paint? White. Biggest worry, many options.
    Thanks in advance.
  2. megcabra
    megcabra Well-Known Member
    1,877
    472
    Aug 12, 2015
    Chapel Hill, North Carolina
    I’ll comment on the painting part and defer any resealing to some other members.
    I think a light sanding would not hurt. Then wipe down with alcohol and tape all up. I’d also recommend using plastic drop cloths to keep the overspray from getting all over. Then get Rustoleum semi gloss white enamel and give it a couple of coats. It is a slow drying paint but will cover nicely. The semi gloss will also hide imperfections in the aluminum skin.
    Best of luck with the project!
  3. tgau16
    tgau16 New Member
    28
    Mar 2, 2016
    RSM CA
    Thanks for getting back to me! Now that I've looked through as many threads as I can, your idea seems to fall in line with most of the previous painters.
    Take care,
    M
    megcabra likes this.
  4. rich2
    rich2 Active Member
    185
    69
    May 3, 2007
    Northampton, PA
    Before painting I would wipe it down with TSP, great cleaner/degreaser
  5. tgau16
    tgau16 New Member
    28
    Mar 2, 2016
    RSM CA
    Tx! I heard chem clean is good too.
  6. Ladiesman
    Ladiesman Active Member
    214
    108
    Feb 6, 2018
    I would not rattle can it myself. To hard to get a good consistant coat and with that large of an area. I sprayed mine with automotive paint but i know not everyone has the experiance or equipment. I have seen some really good results using foam roller and Rustoleum oil based paint. My neighbor did his motor home that way and it came out great. I would just hit the thin spots with a little primer and roll it.
  7. tgau16
    tgau16 New Member
    28
    Mar 2, 2016
    RSM CA
    Thank you!
  8. Ladiesman
    214
    108
    Feb 6, 2018
    How did the paint job turn out
  9. tgau16
    tgau16 New Member
    28
    Mar 2, 2016
    RSM CA
    Its a slow prepping process. I will attach pics when finished.
  10. jnc
    3,920
    1,168
    Oct 1, 2014
    South Central New Hampshire
    the prep is the worst part of painting but the finish product is worth all the headache.
  11. RollTideRick
    RollTideRick Member
    45
    May 31, 2017
    I would use a scotchbrite scuff pad to sand the rough panel . It will be able to somewhat sand in the recessed areas, then bare metal etch primer for all of the bare spots. This will allow your new finish to adhere well and not peel/delaminate. Good luck!
