No 12 v power
Discussion in 'Wiring' started by Butchsaint, Jun 14, 2018.
  1. Canadian Campers
    Canadian Campers New Member
    May 22, 2018
    Caledonia, Ontario, Canada
    I purchased a 2000 Coleman Fleetwood, but that doesn't matter, I have the same issue as you. A few hours after an electrical storm, during which the trailer was plugged in, I had the lights on for maybe 5 minutes, then a scream like a whistle and a big pop and then no 12 volt power to the lights or the CO2 sensor. I checked the fuses and they were good. I checked the converter for other issues and found it smelled of toasted electronics.
    I had no 12 volt battery, so later with a battery hooked up, the lights and CO2 sensor work, so I can deduct that the converter is gone, as I assume could be wrong with yours as well.
    I haven't decided what to do to repair, but if I can order a new unit for under $200, I think that's the best bet.
    Maybe you should test the 12 volt system with a battery as I did, to confirm it works.
  2. theseus
    theseus Centerville, OH
    2,896
    441
    Feb 6, 2007
    Centerville, OH
    The converter itself was blown. Thus you had no DC power when plugged in but had it when connected to a battery which doesn't use the converter.
    You can get a WFCO replacement for about $125 or perhaps less if you shop around. I put an 8740 in both my 99 Palomino and my current 98 Coleman. It's not a hard job.
    Oh and by the way it's not a CO2 detector. Most likely it's a propane detector that might be a combo CO unit. There is a big difference between Carbon dioxide (CO2) and Carbon monoxide (CO) ;)
    Fless likes this.
