No Gas Flowing to Surburban Water Heater
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by David Branley, Oct 21, 2019.
  1. David Branley
    David Branley Member
    34
    Jul 31, 2018
    Hello,
    I have a surburban sw6p water heater in my 2007 Fleetwood Sunvalley which i have not been able to light.
    - Gas Tank Connected
    - Lines purged of air and galley stove lights with no issues
    This model has a pilot light that you must manually light. Following the process to light the pilot no propane seems to flow to the pilot or into the main burner.
    I suspect that the gas valve itself, i assume a solenoid is not working. Has anyone encountered this before and if so any times on repairing or replacing the valve? Anything else i should check?
    I found a replacement valve online here but at over $150 its pretty pricey. I'm wondering if i would be better to look at an updated replacement unit with DSI?
    Any advice appreciated,
    David
  2. NMroamer
    NMroamer Well-Known Member
    524
    267
    Apr 21, 2016
    Albuquerque NM
    There is a thermocouple that the pilot light heats to open the gas valve. Check that first,they usually go bad.
  3. David Branley
    34
    Jul 31, 2018
    The challenge is that there is not even gas getting to the Pilot so i cant even light that.
  4. Sjm9911
    4,526
    2,328
    Is air coming out of it at all? If you hold a lighter there does the flame blow?
  5. David Branley
    34
    Jul 31, 2018
    No, dosent seem to be anything moving at all from what i can tell.
  6. Sjm9911
    4,526
    2,328
    Next is to disconnect the regulator and see if there is propane flow behind it. If there is its the peice you linked, if not bad propane line.
  7. Sjm9911
    4,526
    2,328
    Or something in the feed line.
  8. joet
    4,701
    926
    It takes forever for the gas to get to the pilot, since there is such a small flow.
  9. Sjm9911
    4,526
    2,328
    It definitely does, but there should be air blowing the flame.
  10. crackerJack
    crackerJack Well-Known Member
    1,142
    306
    Jan 6, 2014
    Scottsville, KY
    X2, I would check for gas flow to the heater before I swap the gas valve.
    -Close gas tank, disconnect the gas line to the water heater, open tank briefly.
  11. nineoaks2004
    7,308
    3,046
    Dukes, Fl
    Try closing the tank valve, then slowly open the valve, if opened to fast the safety in the tank will not let full gas flow thru as it detects a leak somewhere..
  12. David Branley
    34
    Jul 31, 2018
    The Gas is flowing to the galley stove so no issue with tank or regulator.
  13. David Branley
    34
    Jul 31, 2018
    That is a good idea, I will try that tomorrow. If I have gas there then I can be 100% certain it’s with the gas valve unit on the water heater.
  14. Bowman3d
    Bowman3d Well-Known Member
    790
    267
    Apr 13, 2015
    LaLa land (SoCal)
    Spiders like to crawl into the orifice and clog them had that happen with my refrigerator.
  15. joet
    4,701
    926
    It can take up to 5 minutes for this model. The pilot has such a small flow (flame) it would be hard to tell if it was blowing air. There is no way a spider could get in to plug the orifice
  16. Dan Wilson
    Dan Wilson Active Member
    169
    134
    Jan 30, 2019
    Appleton, WI
    I would replace the thermocouple before doing anything else. Doesn't cost much and is the most common cause of failure.
  17. crackerJack
    1,142
    306
    Jan 6, 2014
    Scottsville, KY
    Thermocouple failure would not prevent the flame from igniting initially.
    It would ignite, then go out.
    (not stay lit)
  18. Dan Wilson
    169
    134
    Jan 30, 2019
    Appleton, WI
    True, but a thermocouple is essentially a switch, designed to turn off the gas flow if no heat is detected, however, a failed thermocouple could fail, leaving the switch in a permanent off state.
  19. crackerJack
    1,142
    306
    Jan 6, 2014
    Scottsville, KY
    I have serviced many water heaters. I disagree.
