No Lights Inside
Discussion in 'Wiring' started by Arkansascorey, Aug 1, 2019.
  1. Arkansascorey
    Arkansascorey New Member
    18
    Mar 9, 2017
    Arkansas
    I know that I screwed up somewhere, just don’t know exactly what I need to have fixed. On my recent camping trip I was turning on my 3-way fridge thinking I was turning it on the shore power switch. Little did I know I realized I flipped the red switch for 12V and my battery isnt hooked up. I think something bad happened when the lights inside went off and so did my carbon monoxide detector. I checked for blown fuses, everything looks good. Outlets in the pup work fine and so does A/C. What did I do??
  2. Sjm9911
    6,410
    3,778
    Check the fuses.
  3. PopUpSteve
    PopUpSteve Administrator
    19,181
    1,947
    Dec 22, 2002
    Malvern, PA
    Kill switch stuck?
    myride likes this.
  4. Arkansascorey
    18
    Mar 9, 2017
    Arkansas
    I don’t think I have an actual switch I just have a cord I have to connect under the sink
  5. myride
    myride Well-Known Member
    985
    464
    May 14, 2015
    Edmonton, AB
    Hmmmmm......doesn't sound right to me......but can't say for sure. When it happened to me it was a sticky switch.
  6. Raycfe
    16,976
    2,530
    You overloaded the convertor ........ should be a fuse somewhere on it.
    Arkansascorey likes this.
  7. Sjm9911
    6,410
    3,778
    Sometimes the fuses don't look blown but are. I would just replace them first. Then go from there.
  8. Arkansascorey
    18
    Mar 9, 2017
    Arkansas
    I will try this! Thanks
  9. Arkansascorey
    18
    Mar 9, 2017
    Arkansas
    Hope I don’t need a new converter!
  10. SteveP
    SteveP Well-Known Member
    1,666
    492
    You'll need a multimeter. Plug in the camper. Set the multimeter for the 20 volt DC range and connect the probes to the battery positive and negative wires. If you see less than 13.2 volts the converter is not providing power. Some of the older converters had internal glass tube fuses soldered in place, if you want to look for and deal with that.
    If you see voltage you'll need to check the amps. Move the positive probe to the 10 Amp connection and set the dial to the 10 Amp setting. And touch the wires again. You need to be very quick about this because the probe wires on the multimeter will heat up quickly if there's any current. And if the current is more than 10 Amps you will have to replace the fuse in the multimeter.
