No power from battery
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by Sokokis, Aug 4, 2013.
  1. Sokokis
    Sokokis New Member
    29
    Feb 18, 2012
    Hi all -
    Set up in camp driveway to make sure everything is functioning properly and discovered that there is no power from the battery to the pup. Everything functions on shore power, the battery is fully charged, and the fuse that blows if the polarity is reversed on the converter is fine. Any ideas? I'm not great with electricity, so please use short words and simple terms! :)
  2. kitphantom
    12,841
    1,901
    One frequent issue is the cut-off switch that prevents power being on to the inside of the pup when it is shut. On our Cobalt, it is under the flip-over galley, and occasionally it is not switched when I flip the galley. (It has behaved better since DH made sure the wood pad that triggers it was even.)
    The cut-off switch may be in a different place in our pup, it would be helpful if you would add your pup's make, model and year to your signature line. That way people may have a specific answer for your pup, especially if they have encountered the same issue.
    Others have encountered connectors that have become unplugged, such as in wiring leading from bottom to roof, sometimes hidden between roof edge and tenting.
  3. Campit
    Campit EAT SLEEP CAMP
    1,638
    Sep 16, 2011
    Taking a wild shot...did you flip your switches in your coverter box from ac to dc?
    Campit
  4. Unstable_Tripod
    14,279
    48
    May 20, 2008
    Seattle, Washington
    Older converters required a manual switch but newer ones do that automatically.
    There may be an in-line fuse in the positive battery cable. Check to see if one is there and if so, if it is intact or blown.
  5. Sokokis
    Sokokis New Member
    29
    Feb 18, 2012
    Thanks for the help. I had missed one of the main fuses in my testing and of course that one was the culprit!
  6. Raycfe
    17,257
    2,854
    Glad you got it fixed.
