No Propane flow from internal and external stove quick connects
Discussion in 'Propane - Got Gas' started by Deborah Wherler, Sep 2, 2019.
  1. Deborah Wherler
    Deborah Wherler New Member
    Sep 1, 2019
    Fountain Hills, Az
    I posted this on the general first
    Hello All!!!
    What a summer. First (and only) trip out, I found myself without propane throughout my system... after Exhaustive troubleshooting on my own with no results, I brought my trailer in for repair. $235 later the professional replaced my two stage regulator to a single stage, changed the hose to the reg to the system, leak checked and tested all except my outdoor and indoor stove quick connects (please no comments on the pro, I get it).
    So I have tested all as well, hot water, check, heater, check, fridge, check. Stove connections NOTHING!!! They worked fine the last time I used last year. Anyone have any ideas? Oh I do have a camp Chef that I hook up to the outside connection, again no flow.
  2. tombiasi
    5,209
    901
    He should have installed a two stage regulator.
  3. Sjm9911
    4,154
    2,060
    Did you answer my other questions? This is a process of elemination and without the information we cant begin to help.
