No wires for battery
Discussion in 'Wiring' started by iamcurtanderson, Aug 6, 2019.
  1. iamcurtanderson
    iamcurtanderson New Member
    Aug 6, 2019
    I've got a 1996 Coleman Santa Fe.
    I'd like to add a battery but there are no wires visible to connect one.
    I've done a little research and it seems I should be looking for black and white cables.
    Where would these cables be hiding?
  2. eoleson1
    eoleson1 Well-Known Member
    2,419
    814
    Jul 5, 2011
    Macomb County Michigan
    They would probably be hiding in the frame channel between the tongue and the converter. I would look at the bottom below the converter for wires coming through the floor.
    tombiasi likes this.
  3. GreyFox
    GreyFox Well-Known Member
    1,974
    981
    Oct 10, 2018
    S Ontario
    Look harder, you should find a harness exiting the trailer frame near the battery location that consists of a black wire & white wire, both of which terminate with a white plastic connector that would plug into this battery harness ...
    ... which you would connect to the battery.
