Noob question....
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by Wayovrpar, Aug 7, 2019.
  1. Wayovrpar
    Wayovrpar New Member
    Jul 31, 2019
    if my converter charges my battery while connected to shore power....why do I need a maintainer during off season? Can I just leave it plugged in?
  2. joet
    4,824
    982
    You could leave it plugged in, but convertors don't do the best job of maintaining a battery
  3. Raycfe
    15,571
    1,688
    They may have a chance of overcharging them and boil out the water in the batteries.
    It would also be a good idea to disconnect the battery over a long period, even remove it from the camper
    PopUpSteve likes this.
  4. Snow
    10,291
    1,142
    Depending on the year of your trailer, the make and model of the converter and the year it was built, It may be just a straight forward charger like the old car chargers were, putting out a fixed number of amps until disconnected, it could be a two stage charger which will give a high amp charge until a certain % of charge is back on the battery then drop the supplied amps by about 50% for as long as the trailer is powered, lastly it could be what is called a smart charger that while similar to the two stage also has a maintain function that once the battery reaches about 90-95% capacity it will trickle charge and cycle on and off to maintain the battery at over close to 100%...
    So what is the converter info ?? that is the important question ..
  5. Wayovrpar
    Jul 31, 2019
    Centurion 3000. Trailer is a 2000 Flagstaff.
  6. giadiep
    giadiep Active Member
    416
    181
    Sep 5, 2015
    Syracuse, NY
    I pull my battery out and bring it inside the house during the winter. Cold weather is not good for a battery. I do not "trickle charge" the battery though. Just charge it up fully before storing it for the winter and fully charge it in the spring before re-installing.
    hayyward likes this.
  7. kitphantom
    11,859
    935
    With our '10 Coleman pup, we just pulled the battery for the winter, and put it on the charger once a month.
    We were doing the same with the dual 6 v batteries on the TT, but they are a pain to get in and out of the tight quarters on the TT's a-frame. Last winter, we just left it plugged in, but we suspected that batteries were ready to be replaced, after 4 full seasons, including a stressful first season with them, when we chased an electrical gremlin for months. I'm not sure what we'll do for the off-season this time; it's basically from Dec 1 until Feb. or early March.
  8. tfischer
    tfischer Well-Known Member
    3,587
    1,083
    May 21, 2014
    Same here. I do the same thing with our lawn tractor battery.
  9. Annunzi
    Annunzi Member
    42
    Jun 14, 2019
    Vancouver Island, British Columbia
    We keep our pup in our garage over the winter and I leave it plugged in. Been doing this for 4 years with a group 24 battery and I've never had an issue with the battery losing it's charge (our first trip of the year is 3 days and we usually run the furnace and water pump, although we have upgraded to LED interior lights).
  10. Snow
    10,291
    1,142
    At best you will have a two stage charger.. Could boil the battery dry and destroy it..
  11. NavarWynn
    NavarWynn Member
    78
    37
    Jul 20, 2019
    SAV, GA
    ^^^ This. No way a 2000 model year has a smart charger. Leaving it plugged in will likely kill the battery.
    Frankly, unless it gets blisteringly cold, I'd leave it in, disconnect the B+ post (I personally like to have the B+ post switched to make connection/disconnection simple), and attach a maintainer charger. A fully charged battery has to get pretty cold to do damage to it (~-90F), but a partially discharged one freezes at a much higher temp (SOC 40% = ~-16F), and the more discharged, the closer to 32F it will freeze. If it freezes, it'll likely never work right again. The maintenance charger is the critical component though, since a LA battery self discharges at 2-6% (depending on temp) per week, in a cold region, a winter un-maintained will almost certainly result in a frozen battery.
    However, just pulling it off the TT, and taking it inside isn't ideal either - not without a maintenance charger. Self-discharge means that, regardless of temp, if the charge is un-maintained, the acid breaks down, leaving the sulfur detached and able to crystallize on the plates (sulfation is the technical term) - which is what it does when ionic sulfur sit in the cell, undisturbed, for a while. Those crystals don't recombine to form electrolyte (when charged) well, which degrades the battery's capability considerably - sulfation is one of the primary killers of LA batts. You never want to leave a LA battery for extended periods with anything less than a full charge.
