Not enough power for electric lift
Discussion in 'Lift Systems' started by Dont slow down, Aug 13, 2018.
  1. Dont slow down
    Dont slow down New Member
    19
    Aug 13, 2018
    Hello! My wife and I recently purchased a 2015 Columbia Northwest / Somerset pop up and it has a electric roof lift system. I grew up camping in pop ups since I was a kid and they all had manual cranks. The people we bought the trailer from told us the lift never worked on its own on battery power and they always used shore power to lift it. I confirmed this and It won’t raise, the motor just clicks but never turns. The trailer is equipped with a marine deep cycle battery and my initial thought was that the battery was just low. Well after charging it it still doesnt have enough juice. My second thought was to get a battery with more cold cranking amps, but most batteries that are higher rated aren’t deep cycle. I read about doing a 6v battery setup but from my understanding that would give me longevity but not initial amp strength. I also thought about adding a second battery in parallel, but I’m not sure that would give me enough amps either. Can anyone offer any insight? Are there any places I should check in the mechanical lift system for resistance, ie greasing areas? Thank you!
  2. NMroamer
    NMroamer Well-Known Member
    635
    349
    Apr 21, 2016
    Albuquerque NM
    How old is your battery? If it is over 3 yrs old I would seriously think about replacing it.
    Batteries unlimited is one place to look for a replacement.
  3. Dont slow down
    19
    Aug 13, 2018
    I'm assuming it's the original battery, so it might be around 3 years old. But replace a 3 year old deep cycle battery?? Even so the original owners said the roof never raised on the battery from day 1. If I do replace it should I get another deep cycle? Or a regular battery with more cold cranking amps?
  4. mpking
    mpking Well-Known Member
    1,326
    333
    Jun 17, 2014
    Raynham, MA
    Deep Cycle. Cold Cranking Amps aren't really beneficial to a camper.
    The problem is either:
    • The battery is shot, and not providing enough volts when a significant draw is drawn
    • The motor has a problem
  5. Dont slow down
    19
    Aug 13, 2018
    The motor works fine when I'm plugged in to power, and it even lowers the roof on its own when only on the battery. I think it's just a amperage issue.
  6. Orchid
    Orchid Sharp Shootin' Grandma
    5,583
    2,398
    May 8, 2011
    Florida by way of WV and MD
    I wonder why they would buy a brand new camper with a lift that didn't work with the battery? I know this is not the question, and I'm no help with that. Just curious about the situation. [?]
    WVhillbilly likes this.
  7. joet
    4,965
    1,057
    Before I would throw money at a battery. I would check all the connections making sure they were clean and tight and check the amp draw of the motor.
    neighbormike likes this.
  8. roybraddy
    roybraddy Well-Known Member
    2,307
    848
    Mar 23, 2016
    King George, Virginia
    I have jumped my batteries with my truck a couple of times when my roof lift batteries have run down some... Extra juice helps sometime...
    Your setup sounds like it may be miswired or a fuse or DC circuit breaker tripped or some. Maybe the REVERSE POLARITY fuses are blown... Both the battery connection and the DC Power from your 120VAc Power Converter should feed the Trailer 12VDC Distribution Panel at the same point.
    Roy Ken
  9. mstrbill
    mstrbill Active Member
    692
    145
    Mar 17, 2013
    Austin , Texas
    Test the battery, you don't know how the original took care of it. They could have never disconnected and let it discharge too many times damaging the battery. How do the other 12V items work on the battery?
  10. Dont slow down
    19
    Aug 13, 2018
    I wondered that too, they said they took it back to have other things fixed after delivery. Makes me think the dealer was trying to pull a fast one or something.
    Orchid likes this.
  11. Dont slow down
    19
    Aug 13, 2018
    We are taking the trailer out this weekend so I will test some other 12v items while we are out. So far in the driveway the lights work great, it runs my fans, and we'll other than the fridge that's all I have. My voltage reads 13.8v with no load on it, I've had it on the charger the last few days. I'll see what I can get from the lift on a full charge. Another thing that I found odd is they said the battery never charged when hooked up to shore power. They said it doesn't have an inverter. However I believe it does. I'm wondering if something is wired incorrectly
  12. BikeNFish
    BikeNFish Well-Known Member
    3,355
    2,266
    Apr 24, 2017
    Maplewood, MN
    The power winch on my pup barely has enough power to lift the roof unless I have the trailer level and have not deployed the stabilizers. If the pup is level and the stabilizers are up, it lifts just fine.
    She's a fickle girl.
  13. emoney
    emoney Well-Known Member
    880
    451
    Jul 7, 2018
    Sounds like something isn’t wired correctly. One quick way to find out if it’s a battery issue is try a different battery, say from the Tv and see if the lift works. If, by chance, it does why not replace the battery with one of those two way marine batteries.
  14. joet
    4,965
    1,057
    Just because the voltage is 13.8 does not mean the battery is good. If the battery is the original, take it and have it tested. I see this all the time, voltage is up and amp capacity is way down. Where are you getting the volt reading from?
    They were correct in saying the pup does not have an inverter.
    The pup has a converter and it will charge when hooked to shore power.
  15. McFlyfi
    McFlyfi Active Member
    490
    220
    Aug 1, 2014
    Thousand Oaks CA
    My '10 Niagara did the same thing. For sure check the battery polarity.
    I bypassed the original wiring, running a 10 g landscape wire directly from the power distribution panel to the current limiter. Problem solved.
    The original 12g wiring exited the back panel and was scotchlocked to a 14g pigtail. Not enough current through undersized wring and dubious connections caused my problem.
    20 bucks in wire and a half hour in labor later, and my lift works just fine.
  16. gardenbliss
    gardenbliss Well-Known Member
    1,298
    147
    Dec 9, 2013
    San Diego
    I am also curious why they never addressed this with the dealer since it is a fairly new camper. What model is it? I have a Columbia Northwest/Somerset Santa Fe (10 ft), and the battery lifts the roof just fine. I wonder if they tried to bypass the motor at any point in order to hand crank the lift and forgot to reconnect the wires underneath the winch? I'd call CNW and ask them, though I hear they are not very helpful, or else bring it to the dealership where it was first purchased if it is close.
  17. Dont slow down
    19
    Aug 13, 2018
    It's a Mesa I believe. I live in NC and bought it from a couple in PA, so the dealer isn't an option for me. I work as an electronics technician so I'm familiar with wiring. It sounds like I need to do some more testing and digging into it. Actually MCFlyfi has a good point, if the wiring is too small that would explain why it never worked from the beginning. I'll have to get into the "converter" (you are right joet, inverter is DC to ac, converter is ac to DC) and see if I can find a wiring diagram and trace out some of these wires. I'll also take the battery into autozone and see if they can test it for me.
  18. mpking
    1,326
    333
    Jun 17, 2014
    Raynham, MA
    Sounds like you have a plan of action. (I'd have the battery tested first, since it's the easiest thing to do)
  19. joet
    4,965
    1,057
    The converter wasn't designed to power the lift motor. So wire size from the converter to the battery is not the issue
    Put an amp meter on the motor
  20. Dont slow down
    19
    Aug 13, 2018
    I dont think the motor is wired directly to the battery, I only have two wires on the battery, a positive and a negative. That motor is tied in somewhere else along the line
