Obsolete, full propane tank
Discussion in 'Propane - Got Gas' started by heathdavis, Sep 27, 2011.
  1. heathdavis
    heathdavis New Member
    559
    May 15, 2011
    We have an ancient rusty propane tank of the old style, which means it is at least 13 years old. It is too heavy for me to lift (and I'm pretty strong for a girl), so it is probably full or nearly so.
    We will exchange it for a new one but... should we use the propane first? DH is afraid it will be contaminated and ruin his bbq or whatever else we use it for. (Not in the pup, yet, until it gets cold) This seems like a waste, but I said "OK, then put it in the back of my car and I'll go exchange it". Can't get him motivated to do that.
    Should I: 1. Convince him to use up the propane in it
    2. Wait for a windy day and slowly vent off the propane so I can lift the tank.
    3. Kick his a** until he puts it in my car
  2. Yellowkayak
    2,198
    Mar 13, 2007
    Use it up...grill alot of burgers, steaks and hotdogs. Or you can slow cook a large briscuit wrapped in tin foil for about 10 hours on the grill on low. That should use up just about all the propane.
    JJ
  3. Flyfisherman
    Flyfisherman New Member
    3,682
    Mar 4, 2003
    Shallotte, North Carolina
    Yeah ... run it through the BBQ, then exchange the old tank. Use the good, fresh stuff in the camper!
  4. Unstable_Tripod
    14,279
    40
    May 20, 2008
    Seattle, Washington
    I agree: use the propane.
  5. freenaz
    freenaz Member
    823
    Jun 7, 2011
    I say use it up.
    Contaminated?
  6. rabird
    7,147
    489
    N. TX
    If it doesn't have ACME threads for a modern grill to connect to then just exchange it (full or empty). If you have a way to connect to it use it up.
  7. electronflux
    electronflux Member
    825
    Jun 16, 2010
    use it.
    I don't see how it could be contaminated...gas is, well, gas
  8. cwolfman13
    cwolfman13 Active Member
    3,218
    Feb 9, 2011
    Never heard of gas getting contaminated or otherwise expiring.....use up the gas then exchange that tank for a nice new one you can re-fill.
  9. fmbhappycamper
    fmbhappycamper PuP Power
    4,325
    Aug 27, 2010
    make sure the bottom will hold it upright or is it rusted out? [!]
  10. screwballl
    screwballl Stimulus Package
    642
    Aug 7, 2009
    FL
    agreed. You may need to pick up an adapter at the local hardware store to hook it up to the grill. Gas is gas, the regulators and safety features of most newer grills will prevent any bad from happening, and the food will taste NO different.
  11. heathdavis
    559
    May 15, 2011
    re: Contamination--- He's worried that there might be rust-dust in it from the inside of the cylinder and that it will clog up ports or whatever on the bbq. (I don't bbq. ) I don't know whether they rust on the inside-- seems unlikely.
    The cylinder seems solid, though completely rust-coated on the outside.
  12. Hacksaw
    Hacksaw Active Member
    1,875
    Aug 23, 2009
    Cook with it.It will be fine.If there is rust on the inside it will not allow the gas to flow through the valve. Be aware that when "exchanging" it for a new tank it is against the law for them to accept any tank that is older than 12 years,does not have an OPD (triangle knob on top) or shows visible signs of damage including rust.
  13. rabird
    7,147
    489
    N. TX
    What do have that will connect to it?
  14. heathdavis
    559
    May 15, 2011
    Re: Obsolete, full propane tank PROBLEM SOLVED
    After reading Hacksaw's post, I decided to call around to check to see if anyone would take the cylinder. Somewhere I had gotten the idea that the propane exchange places were required to take old tanks.
    The person at Home Depot said "Well, actually it's self-serve. You swipe your credit card, put the old tank in one cage, and get a new one out of another cage. There aren't any humans involved so it doesn't matter". Good enough.
    Then DH came home. When I told him what the Home Depot lady said he threw the old tank in his truck and drove off to HD. He still refused to use up the old propane. I hate wasting things but at least we'll have a new tank.
    Thanks everyone for all your answers.
  15. dackley
    dackley 1999 Jayco Heritage Laurel with popout
    261
    Dec 24, 2010
    COME ON THE TANK ONLY WEIGHS 28 LBS LOADED, YOUR PURSE WEIGHS MORE THAN THAT, TURN THE TANK ON ITS SIDE AND ROLL IT TO CAR, OPEN TRUNK HE WILLL HAVE TO DO IT THEN. IF NOT CALL ME IM IN ATLANTA, ( BUT I MOVED FROM MELBOURNE,FL IN 2007 (31 YRS)
  16. heathdavis
    559
    May 15, 2011
    Um, no, more than that-- and I can roll it but not lift it up high enough.
    See http://www.propane101.com/consumerpropanecylinders.htm
    Ha, you must not know bout me. [:D]
    (I hate purses.)
    [:D] Thanks but I got it covered (finally!)
    PS MODIFIED AT 7:28
    Well crap!! DH came back with the new cylinder and I can lift that one up with one hand! The antique must have been made of thicker metal. I'm not a wimp after all!! Yay!
  17. fix_it
    fix_it Member
    595
    Aug 29, 2010
    That is why I don't use the exchange places unless I have to. Those exchange places only fill their tanks 3/4 full!!! Now that you have a new tank, find somewhere to get it filled. It's generally cheaper to get 18 lbs at the refill place than 15 lbs at the exchange place.
