OCD Leveling
Discussion in 'Leveling Your Camper' started by Sandman51, Nov 3, 2021.
  1. Sjm9911
    10,790
    8,170
    Coat the board with grip paint, or use a peice of rubber in between. Rubber is probably the best option.
    BillyMc and DiamondGirl like this.
  2. Dingit
    Dingit Well-Known Member
    1,816
    1,278
    Mar 8, 2017
    I've had to raise one side of my camper more than the Anderson leveler can accommodate. The Bal goes a bit higher, unless you have a wee tire.
  3. BikeNFish
    BikeNFish Well-Known Member
    4,167
    3,156
    Apr 24, 2017
    Maplewood, MN
    Yeah... I did put some anti-slip tape on the Anderson Leveler but I only had marginal success. The Anderson is so slick that the tape started to slide off. And now you have arrived and surpassed the point of defeating the whole purpose of the Andersen leveler - simple and easy leveling. Trying to modify the Anderson just complicates it. May as well just use leveling boards. Now I'm back to where I started.
  4. Sjm9911
    10,790
    8,170
    I wouldnt use tape. The glue is the weak point. Spray can of grip, or hard rubber matt. I did sink a little once, but so did all the stabilizers. It wasnt bad. If I camped in those places all the time, i would just get a hard rubber matt for like the gyms. Just lay it down , then put the levelers. My TT is dule axel, so I cant use a bal. The pup was much lighter. I never had a problem.
    DiamondGirl likes this.
  5. BikeNFish
    4,167
    3,156
    Apr 24, 2017
    Maplewood, MN
    I would think that if the tape comes right off, so will anything you spray onto it.
  6. Sjm9911
    10,790
    8,170
    Its a spray grip, it lasts a while, it does ware off. I used it on rentals I had when people said the stairs were to slippery. It works. Alternatively, sand and expoxy paint. After it cures it will not come off. Depends on what you want.
  7. BikeNFish
    4,167
    3,156
    Apr 24, 2017
    Maplewood, MN
    And if I paint a turd gold, it's still a turd. Just sayin'.
  8. LilRed
    LilRed Well-Known Member
    740
    364
    Jan 9, 2021
    Long Island NY
    the rubber coating on the curve wedge I posted earlier was the deciding factor for me. I haven't had any slippage on hard surfaces, but I have had issues with wheels, wedges, lynx, and stabs sinking into soft fields while camping..
  9. tfischer
    4,751
    2,359
    May 21, 2014
    I've used them on top of Lynx blocks with no issues one time at a site that needed more lift than the Andersen allowed for.
    DiamondGirl and BikeNFish like this.
  10. Wrenchgear
    3,610
    858
    Aug 5, 2010
    5 Star Eagle Camper
    Dig a bit of a hole for the wheel on the other side. Sometimes I just dig the hole for the high side, and thats all thats required, no lynx needed on the other side.
  11. Sjm9911
    10,790
    8,170
    But its gold now[:D]
  12. Snow
    11,817
    2,394
    Somewhere I have a picture from one of our Ontario Summer Rallies, of T'N'T trying to level their TT using the Anderson Levelers on wet ground (we are talking soaked by multiple weeks of rain, wet ground). if the Andersons weren't just sliding along the grass, they were just sinking. In the end, they had to borrow 3 bags of my lynx Levelers to use under the Andersons Levelers ..
  13. tfischer
    4,751
    2,359
    May 21, 2014
    So somehow the Bal is immune from sinking into saturated muddy ground? I doubt it lol.
    Use what works for you, but I've been very happy with the Andersen.
  14. Anthony Hitchings
    3,188
    1,895
    Mar 2, 2019
    Oakland, California
    I used Liquid Nails to glue 60- grid sandpaper to both sides of the boards that use for levelling. Only becasue sometimes a situation on one side of the camper is vertically challenged.
  15. Sjm9911
    10,790
    8,170
    I always have extra blocks of wood and legos. You never know when there needed.
  16. Dingit
    1,816
    1,278
    Mar 8, 2017
    If you're in a campground--even an unpaved rough unlevel one--please don't dig holes in the parking area. :)
  17. DiamondGirl
    DiamondGirl Adventures with KODI in AZ
    1,153
    1,129
    Jul 2, 2016
    AZ
    I used the Camco Slip Pad for my Andersen leveler. It helps from slipping. I’ve used my Andersen on additional block levelers. Sometimes you need more height like at my last trip to the lake. 1.5-2ft higher. BAL wouldn’t work at that height or weight and the Lynx levelers would sink into the sand. Our camping neighbor dug the opposite side tire to level his TT and was stuck in the dirt when trying to leave.
    https://www.amazon.com/Camco-Slippi...E,B0024E6QX0,B07PDHQ1HT,B00HJ6O4A0,B0000AXQU2
    @Sjm9911… I’ll tell DH to spray it with grip paint before our next trip to the lake. All our other camping spots don’t require much but the Andersen. There’s rarely any grass camping sites in AZ.
    Happy Camping…[put&hy]
  18. Patrick w
    Patrick w Active Member
    323
    137
    Aug 13, 2021
    I bet your site is better. Mine is mostly on dirt and grass, and it's not the front yard or on a golf course. Unless your staying at a "resort" most are not concrete or gravel pads where I am. So yes, I do have a curved leveler when applicable, but the bal always works, and has as close to infinite adjustability without other variables.
    Snow likes this.
  19. Patrick w
    323
    137
    Aug 13, 2021
    It has happened. Only because the area was so overgrown, it was either have a tree branch rubbing up against the canvas when the wind blew or move over a foot. Moving over the foot had someone's I got stuck so I spun the tire divot. A good site is a good site, but as my trips are often last minute I take what I can get.
  20. Patrick w
    323
    137
    Aug 13, 2021
    People do this?
