Old ABS Roof Scraps for Repair
Discussion in 'Roof/Floor Repair & Maintenance' started by AScott, Aug 11, 2019.
  1. AScott
    AScott New Member
    Aug 20, 2018
    Northeastern MN
    I tried a search for this, but there were so many results with these words it was overwhelming.
    Has anyone tried using ABS roof scraps instead of virgin ABS or airsoft pellets for a roof repair? Since it already has the UV protectant in the formula, would it hold up better if not covered with Grizzly Grip right away?
    I'm just curious, not sure where one would even source it. The thought just popped into my head while thinking about the inevitable on our NTU Coleman Sea Pine.
  2. Raycfe
    15,397
    1,574
    The pellets were so much easier to work with.
    xxxapache likes this.
  3. Sjm9911
    4,699
    2,450
    If your at the point of a repair like that, it will not matter. The rest of the roof thats not repaired will be old and still need to be sealed.
  4. AScott
    AScott New Member
    Aug 20, 2018
    Northeastern MN
    That's a good point.
  5. bheff
    bheff Well-Known Member
    954
    465
    Feb 24, 2011
    NW Arkansas
    Harbor freight sells an ABS plastic welding kit. I dont know enough about the roofs and what all is mixed with the ABS but for $56 I would give it a try.
    HeatherBlü likes this.
  6. popuperfromwayback
    popuperfromwayback New Member
    Aug 20, 2019
    Another option to consider is a product I've used in my trade (commercial ice machine service). Hoshizaki Ice Machines use an ABS interior that suffer from cracking overtime due to thermal cycling and ice crashing down on some parts during the harvest cycle. Their solution is an ABS repair kit consisting of ABS chips and a small thin sheet (4" x 4") that you mix with acetone available at any home depot. We use a mason canning jar and mix this up as needed for these type repairs. Their part number is HS-0130KIT. If you search the webs for that item you'll find it readily available and cheap. Hope this helps others. I'm about to apply this to my newly acquired pristine 96 Coleman with minor roof cracks.
  7. MarkesOlliver
    MarkesOlliver New Member
    Sep 2, 2019
    If i was in that problem, i would ask roof repair expert to do whole roof repair.
  8. Sjm9911
    4,699
    2,450
    The problem is not many will work on them ,and the cost is usally way more then the pup costs.
  9. popuperfromwayback
    Aug 20, 2019
    It really comes down to how bad is the original abs and how much time do you want to put into it. Drilling, grooving, patching then sanding those cracks are easy enough but tedious to do it right. These are awesome little campers but that roof just wasn’t made to stand the test of time.
  10. popuperfromwayback
    Aug 20, 2019
  11. popuperfromwayback
    Aug 20, 2019
  12. popuperfromwayback
    Aug 20, 2019
    Sorry for the repeating post. Working from my phone and it didn’t update when I posted.
  13. phoodieman
    phoodieman Active Member
    794
    99
    May 18, 2009
    Hutto, Texas
