Older Model Flame King RV Grill
Discussion in 'Propane - Got Gas' started by Paladin29, Oct 10, 2021.
  1. Paladin29
    Paladin29 New Member
    Apr 21, 2021
    Phoenix
    Looking for the right quick connect hose for an older Flame King RV grill. Any ideas on how to locate one?
  2. Sjm9911
    10,618
    8,000
    Quick connect to what? There are diffrent fittings. And some grills will not work on low pressure. What are you trying to conect? High or low pressure stove, with what fottings, to what, High or low pressure?
  3. Paladin29
    Apr 21, 2021
    Phoenix
    Connection from popup is a quick connect, will need a male connection, on stove will need a female with inside threads. stove is a small 1 burner.
  4. Sjm9911
    10,618
    8,000
    Ok , so your pop up has a low pressure quick connect fitting. There should be a number on it. There are a few types, depending on when it was made. If your stove is low pressure it will work. If it isnt, it probably will not work unless you remove the regulator on it.
  5. Sjm9911
    10,618
    8,000
  6. Sjm9911
    10,618
    8,000
