Onboard battery charger
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by Party of 5, Feb 6, 2020.
  1. Party of 5
    Party of 5 New Member
    21
    Jan 5, 2020
    When we bought our 97 Sun Ridge it was partially being redone. I'm not sure where this is supposed to plug into. Does it somehow go into the converter?
  2. tombiasi
    5,404
    1,045
    Does it have a power input plug?
  3. Party of 5
    21
    Jan 5, 2020
    No, not that I can see. The other cords go behind the wood.
  4. tombiasi
    5,404
    1,045
    power has to go in and out somewhere. If I could see the connections I could answer your question.
  5. drocks
    drocks Member
    82
    24
    Jul 15, 2015
    That looks like a battery tender trickle charger. They usually have a power cord that plugs into a 110 v outlet and then two wires with alligator clips to connect to the battery. It's designed to provide a slow low amperage charge over a long period of time.
  6. joet
    4,810
    979
    It is marked as a battery maintainer/charger. It is a Harbor Freight item
  7. bheff
    bheff Well-Known Member
    1,012
    508
    Feb 24, 2011
    NW Arkansas
    @Party of 5 put the make and model of your pup in your signature. It will help others know what you have.
    Your converter may be able to charge the battery, but if the P.o. installed that one, then the Converters charger may be bad or non-existent. More info always helps us out.
    Like Tombiasi said, pics of the wires coming in and out of it will help as well.
  8. rabird
    6,738
    313
    TX
    Unclear how this is 'wired' but it is intended to 'plug into' a regular household outlet with the ring terminals connected to a battery. How is it wired/'plug into'? Tracing some wires will be required which would lead to better understanding of you electrical system.
  9. Raycfe
    15,530
    1,665
    Here are the important pages of the manual. Screen Shot 2020-02-07 at 9.54.28 AM.png Screen Shot 2020-02-07 at 9.54.58 AM.png Screen Shot 2020-02-07 at 9.54.58 AM.png Screen Shot 2020-02-07 at 9.54.03 AM.png Screen Shot 2020-02-07 at 9.55.24 AM.png
    bheff likes this.
  10. Raycfe
    15,530
    1,665
    In this case RED would go to positive terminal and black to the negative.
  11. Party of 5
    21
    Jan 5, 2020
    Thank you for the responses. So it appears the red and black ones are going into the converter.
  12. tombiasi
    5,404
    1,045
    That's probably where the battery connects.
  13. Party of 5
    21
    Jan 5, 2020
    Yes, but just wondering what I'm supposed to do with the black and white wires coming from the other end that I originally was asking about.
  14. tombiasi
    5,404
    1,045
    If the black and white wires are coming from the battery, the white goes where the charger black is and the black goes where the charger red is.
    I'm assuming your converter doesn't charge.
  15. Party of 5
    21
    Jan 5, 2020
    No the wires are coming from the charger. See the original post for the picture.
  16. Party of 5
    21
    Jan 5, 2020
    Here again is the original photo
  17. tombiasi
    5,404
    1,045
    The black and white from the charger are to go to 120 VAC.
    Party of 5 likes this.
  18. davekro
    davekro Active Member
    400
    81
    Aug 30, 2019
    SF Bay Area, CA
    See your (pre-modified) device in post #8 by Rabird. See the right side of his picture. Originally your white and black wire had a 120 v ac grounded plug on it. The green ground wire was probably cut short/off. To use this device to trickle charge your battery, you’d need to put a plug on it and connect it via an extension cord to a shore power outlet at home or at an RV w/ hookup site.
    tfischer and Party of 5 like this.
  19. Party of 5
    21
    Jan 5, 2020
    Thanks!
