One drain to rule them all!
Discussion in 'Plumbing Systems (Blue, Grey, & Black)' started by Old ackpacker, Jun 30, 2020.
  1. Old ackpacker
    Old ackpacker Member
    88
    72
    Sep 4, 2017
    Southern Illinois
    My Viking 2460 has the combination shower and cassette toilet (aka “shoilet”) on the front and the sink on the back. Of course the drains are not together on the same side. And they are different sizes. The sink drain is a garden hose fitting and the shower drain is 1.5 inch PVC with a screw on cap to cover it.
    Not only that but dumping the gray water jug a couple of times a day is a pain and the big gray water totes are pricey. So the challenge was to figure out an inexpensive way To tie the two drains of different sizes on opposite sides of the pup together so that they could drain into a sewer hook up at the campground.
    Below is my solution.
    First, because the shower drain exits at an angle I needed a way to get a section of PVC to run under the pup and come out near the sink drain in the back. I found this at Lowe’s and it did the trick
    https://www.lowes.com/pd/Road-Home-1-1-4-in-dia-ABS-P-trap-Fitting/1002620080
    I glued in a section of 1.5 inch PVC that ended just shy of the frame on the backside and glued on a female fitting so I could cap it off.
    This kept everything nicely tucked away when we’re on the road. Notice the plastic hanging strap. I put a bit of a slope so the water will drain properly and it gives a little flexibility/sway room to deflect any road objects that come its way.
    Then I made a screw in adapter that flairs out to accept a standard sewer hose. I bought the hose kit fittings and glued it in to a 3 inch piece of PVC. (Take the fitting with you when you buy the material to make sure it fits properly. The sewer hose fitting will be a little loose, but not sloppy and glues in fine).
    I screwed the adapter in place and marked the top to put in the plastic male garden hose end (cut the barb end down with a hacksaw) and cemented it in place. The finished adapter looks like this.
    Here’s what it looks like all put together and in use. I bought a dishwasher drain hose and cut it down to connect the sink drain to the system.
    It works like a champ and I like being able to use the shower and not have to drain the gray water jug anymore! Total cost @ $30.
  2. Sjm9911
    8,431
    5,797
    I know who designed these things! Lol. I did the same when i had mine with a flexable pool hose. Your looks good. The shower is nice if you have kids, and now with covid. You will like it i did. Next will be the people asking why a pop up needs a full hook up site! [:D]
    Lori Miller and Old ackpacker like this.
  3. Old ackpacker
    88
    72
    Sep 4, 2017
    Southern Illinois
    Because it’s there! :-D (and I’m getting old and decrepit and don’t like lugging jugs/tanks full of dirty water all over the place to dump it)
    Lori Miller and Sjm9911 like this.
  4. Sjm9911
    8,431
    5,797
    I used to get the super premium sites with my pup in the resort campgrounds, so closer to the pool for my kido. I would be parked in between giant rvs, and they all gave us the stink eye for taking the full hook ups sites. They couldn't belive, i had a shower, toilet and sink in my old pup. You'll like it, especially the part where you dont need to conserve water. So, clean dishes, not just quick washed. [:D]
  5. 911Boulder
    911Boulder Member
    37
    50
    Jan 13, 2020
    North East PA
    VERY cool idea!!! Top notch man!!!
    Old ackpacker likes this.
  6. Sneezer
    2,513
    1,369
    I thought about doing something similar. However, on mine the shower has a dedicated 20gal gray tank, and the dump valve is on the same side as the sink drain, but on different ends of the camper. I also figured out I really didn’t use the shower, so I gave up on trying to come up with a solution. Nice work though.
    Lori Miller likes this.
  7. Lori Miller
    Lori Miller New Member
    Aug 1, 2020
    This is AMAZING!! Mine happen to both be in the same side of pup but opposite ends, I’d never be able to do this myself, I’ll have to see if I can get someone to hook me up with something like this!! Awesome!!
  8. Old ackpacker
    88
    72
    Sep 4, 2017
    Southern Illinois
    PVC is really easy to work with, I’m sure you can do it. :smiley: The upside is you can use full hook-ups. The downside is you use full hook-ups. :grin: I’m back to square one at sites that that are electric and water only.:(
