Outdoor grill, high pressure hookup help!
Discussion in 'Propane - Got Gas' started by natomato, Apr 30, 2021.
  1. natomato
    natomato New Member
    Jun 13, 2016
    I need some help. We have a NTU 2010 Coleman Utah, and we are having trouble with the outdoor grill. The curbside hookup runs at 16 psi, and when we open the line to the grill it immediately starts leaking at the connection to the grill. We were under the impression that the grill and hose were original parts of the trailer, but when we looked closer the hose said "1/2 psi max." Clearly a 1/2 psi hose has no business being connected to a 16 psi line.
    So here's my question - is this a low pressure stove that a PO mistakenly purchased for this high pressure line? Or is this a high pressure stove and someone just had the wrong hose? The stove itself has a quick connect fitting, which leads me to think it is meant for low pressure. Is there such a thing as a high pressure quick connect for these curbside grills?
    Pictures attached 20210430_201057.jpg 20210430_201107.jpg 20210430_201027.jpg 20210430_201044.jpg show the grill, including the connection on the grill itself, and the curbside hookup on the PUP.
  2. tombiasi
    6,311
    1,899
    The fitting on your camper is a high pressure fitting. The stove has a low pressure quick-connect.
  3. natomato
    natomato New Member
    Jun 13, 2016
    Is there any way to connect the two?
  4. tombiasi
    6,311
    1,899
    If the stove is indeed a low pressure device you cannot run it on high pressure. You need a tap after the regulators.
  5. Snow
    11,335
    1,978
    The good news is you can get something like a Weber Q grill, porta chef and a couple other grills or even a Coleman stove and connect to that high pressure connection..
  6. p
    p Active Member
    629
    210
    Jun 9, 2014
    Alberta
    Get the blackstone...!
  7. rabird
    7,604
    730
    N. TX
    myride likes this.
  8. natomato
    natomato New Member
    Jun 13, 2016
    Update: We ordered a hose to hook up a Coleman camp stove to HP hookup. We bought an old coffee table at a flea market, removed the legs, and drilled some holes to place it on the BBQ support brackets. Now we have a table connected to the PUP on which we can place the cook stove!
    SteveP and Sjm9911 like this.
  9. Snow
    11,335
    1,978
    Looks good..
