Outdoor shower solution?
Discussion in 'Port-A-Potties / Cassette Toilets / Bath Houses' started by firepit, Aug 7, 2020.
  1. firepit
    firepit Well-Known Member
    987
    1,280
    Feb 26, 2020
    Nebraska Go Big Red
    I would like the ability to hose off outside and do not
    want to buy a portable rinse kit or cut into a practically brand new camper.
    Has anyone installed a diverter faucet on their pop up camper sink?
    We never use the kitchen sink but would use some sort of outdoor shower.
    I see just the standard diverter faucet and the faucet with spout also...which i would prefer
    just in case we ever used the sink for some reason.
    I was thinking i could unzip the canvas just enough and run quick connect shower
    hose through.
    My camper has fresh water holding tank as well as pump and water heater.
    Again i would prefer not to cut a hole in a fairly brand new camper so i am brainstorming
    other options.
    Has anyone done this or are there any drawbacks besides the obvious?
    I will attach a couple pics to help explain my thinking.
    Thank you.
    rescamilla likes this.
  2. Sjm9911
    7,388
    4,775
    Good idea. Other ones i have dont look as good. In my basement slop sinks i always make sure the faucet has a thread for a hose to screw on. They are not pretty. If at water hook up site, i always add a wye and a second hose for rinsing.
    firepit likes this.
  3. Sneezer
    2,345
    1,194
    Do you camp with hookups? Could just add a splitter to the spicket.
    Most household faucets have threads, you just unscrew the aerator/screen. You can also buy adapter fittings so you can use a garden hose. That is how we used to fill our waterbeds back in the 80’s.
  4. firepit
    987
    1,280
    Feb 26, 2020
    Nebraska Go Big Red
    I dont know why it wouldnt work unless i am missing something?
    The temprature adjusting could be a pain at first...but u could mark the hot and cold water knobs once u had it close.
    Then u could turn water on to the setting you marked and be done.
  5. firepit
    987
    1,280
    Feb 26, 2020
    Nebraska Go Big Red
    No camping places i go have water hookups...i am thinking of it for a quick rinse off as well as a full shower when i go dry camping.
    My faucet in the camper now has no threaded cap...we have never used the sink either.
    So either way i would have to change that faucet out.
  6. Steveo4090
    Steveo4090 Well-Known Member
    686
    615
    Jun 26, 2020
    Lancaster PA
    I would think the temp adjustment would be the hang up with it coming from your inside sink. You'd use up half the hot water before you got it right lol. Just kidding...but have you looked into any of the portable propane water heaters? I was looking at them for an outdoor shower when we had the pup. Some are pretty decent and not all that expensive really.
    Someone else posted about using their low point drains to make an outside sink...you could use that idea for a shower.
    Post #15 by galsofescape in thread:
    "Moving the sink outside"
  7. Dingit
    Dingit Well-Known Member
    1,090
    583
    Mar 8, 2017
    I think you could adjust the temp on the inside, switch the diverter (with the shower end in the closed position), grab your towel and go outside.
    But if this is something you'd use, it really might be worth it to cut that hole. Good for dishwashing too (I hear).
    Most popups with water heaters have external showers. Have you checked out your plumbing to see if yours might be laid out for the option? It might be easy....
    rescamilla and firepit like this.
  8. firepit
    987
    1,280
    Feb 26, 2020
    Nebraska Go Big Red
    Good point i will look into that.
    As well.
  9. Blackripley
    Blackripley Active Member
    217
    161
    Jul 21, 2018
    Goleta Ca
  10. PathfinderESP
    PathfinderESP Member
    33
    38
    Jul 9, 2020
    Maryland
    The hole might be worth it... The units aren't huge so it's not a great hole.
    The shower assemblies I have see are only $45 and up.
    We use ours in a pop-up shelter next to the trailer.
    Great for giving the kids a bath (and sometimes adults)
    The 5ft hose they come with is too short... I need to get a longer one so we can put the shelter further away from the Furnace and DHW exhausts
  11. gardenheather
    gardenheather Member
    39
    28
    Sep 17, 2019
    Blackripley likes this.
  12. kcrouth
    kcrouth New Member
    May 3, 2015
    Durham NC
    we are also considering an outside shower rig of some sort for our 2002 PuP - When an outside shower is used in a campground, does the "gray" water need to be collected? or can it just drain away on the ground? It probably has something to do with if and what type soap (?).
  13. Sjm9911
    7,388
    4,775
    Mostly it needs to be collected. No matter what.
  14. Blackripley
    217
    161
    Jul 21, 2018
    Goleta Ca
    They are super old fashion but it does the job, and I would do something cheap like this first and see how it works out. Maybe it is enough, or upgrade.
    In most campgrounds, you will have to collect the gray water it all depends on the site's rules there are some good ideas on collecting on here: https://www.popupportal.com/threads...n-w-outdoor-shower.122297/page-2#post-1291116
  15. Waitara
    Waitara New Member
    Sep 12, 2015
    South Central PA
    Not really to the OP,but to some of the replies discussion these option: I bought a Camp Chef propane heater and love it. I put the pickup line in my wheeled water cart (Like the one you probably use to drain gray water) and hook it up to a 12V pump hooked up to a 12V car jump starter. It works wonderfully completely off grid. A cheap eBay changing/shower tent completes the setup. I have about $200 total in the whole deal.
  16. McFlyfi
    McFlyfi Well-Known Member
    578
    293
    Aug 1, 2014
    Thousand Oaks CA
    I put one of these on our faucet. I occasionally use it to wash my hair in the sink.
    I had also thought about a cheap 2 gallon pump sprayer- heat some water, into the sprayer, hose off. Super cheap, super portable.
  17. Steveo4090
    686
    615
    Jun 26, 2020
    Lancaster PA
  18. Puppylove
    Puppylove New Member
    Aug 26, 2020
    Sonoma County CA
    Ha! This is exactly what I'm thinking of trying. There's the type with a shut off valve near the spray head too. I have one for the dog that attaches to the shower head with an easy push button diverter at the point of connection. Might be just the ticket.
  19. Blackripley
    217
    161
    Jul 21, 2018
    Goleta Ca
    Puppylove and firepit like this.
