Outlets don't work but all lights do?
Discussion in 'Wiring' started by insaniak, May 15, 2016.
  1. insaniak
    insaniak New Member
    26
    Feb 18, 2016
    None of the 3 outlet pairs work, both fuses good 15 & 7.5 and both breakers on. Everything works except the outlets. (Heater fan and lights)
    Two inside under the kitchen table, two near the fridge, and two outlets outside.
    Tested with a phone charger.
    Are the outlets only supposed to work on the 120 DC plug or should they also work from my 12v trailer battery?
  2. ezakoske
    ezakoske Active Member
    506
    66
    Nov 30, 2014
    Escondido, CA
    Your outlets will only work when they are plugged into 120v.
  3. insaniak
    insaniak New Member
    26
    Feb 18, 2016
    Ok, simple enough, thanks.
  4. ezakoske
    506
    66
    Nov 30, 2014
    Escondido, CA
    Or 110v... :)
  5. terry1419
    terry1419 Active Member
    670
    80
    Mar 6, 2016
    Streator, IL
    Your outlets are AC not DC. The 12 V is DC.
