Outlets stopped working
Discussion in 'First Time & New Camper Owners' started by SimonSenz, Jul 18, 2019.
  1. SimonSenz
    SimonSenz Member
    33
    Jun 18, 2019
    We are at a site. Plugged in the heated mattresses for the first time. This morning the outlets are not working but interior lights are fine. We are plugged to a thirty amp. I flicked our breakers but no luck. Is it a fuse? How to tell which fuses to change?
  2. BigAl
    BigAl Member
    57
    49
    May 22, 2019
    Wisconsin
    Did the outlets work initially, then stopped? Could your lights be running off the battery and shore power is out?
    I don't believe any of my outlets are fused, just the breakers. Is your GFCI outlet tripped?
  3. tombiasi
    5,213
    901
    In addition to what BigAl said check the campground pedestal breaker also.
    jmkay1 likes this.
  4. jmkay1
    4,654
    1,562
    I second the above post. Check the campground power first. Many of the places I camp they flip the breaker at the post to off if the site is unoccupied. I've also had it where there wasn't enough power to power the full 30 amps. The campground breaker tripped soon after. Apparently the campground circuit was overloaded. Too many people had their AC and fans running full power. That was a mess and a lot of angry campers.
  5. PopUpSteve
    PopUpSteve Administrator
    18,713
    1,526
    Dec 22, 2002
    Malvern, PA
    This is why I carry a Electrical Ground Checker / Circuit Tester / Grounding Plug
    WVhillbilly and Raycfe like this.
  6. Rusty2192
    Rusty2192 Well-Known Member
    839
    316
    Jul 30, 2014
    Kentucky
    When checking breakers, be sure to flip them fully off first, then on. If they are tripped, they won’t usually reset without first being turned off.
  7. liz.s
    liz.s New Member
    Jun 7, 2018
    Our outlets and fridge stop working when our son pushed the gfci test button without anyone noticing.
  8. 1REDBEARD
    1REDBEARD Active Member
    139
    40
    Jun 11, 2019
    FL
    Mine did the same on our first trip out. I was freaking out and thinking the worst. Like others are saying though I found that our gfi tripped.
