Pads for the bunk door clamps
Discussion in 'PopOut (Hybrids)' started by RugerRedhawk, Aug 13, 2019.
  1. RugerRedhawk
    RugerRedhawk Member
    113
    Jul 17, 2015
    I'm missing one of the pads that goes on the latch, anything specific I should replace it with? trouble coming up with the right google search term.... I have a starcraft travelstar, it has the latches that you swing and latch closed, not screw on clamps. Current pads are white.
  2. HappyTraveler
    HappyTraveler Active Member
    328
    225
    Apr 30, 2019
    New York
    Can you post a picture of what you're talking about?
  3. bikendan
    bikendan Active Member
    522
    37
    Feb 26, 2012
    they're talking about the rubber foam pads on the bunk door cargo latches. if you've never owned a hybrid, you won't know what they are.
  4. Raycfe
    15,609
    1,709
    Mine are a ¼ inch thick rubber just glued on. I wouldn't use foam ---compresses too much.
    Even a piece of rubber mat may work.
  5. RugerRedhawk
    RugerRedhawk Member
    113
    Jul 17, 2015
    Yeah I figure I could try to rig something up that would probably work fine enough, but was hoping to find the OEM solution or something very close.
  6. GreyFox
    GreyFox Well-Known Member
    1,586
    786
    Oct 10, 2018
    S Ontario
    This is a pic of my previoius TrailCruiser hybrid which shows the rubber pad the OP is talking about. Nothing special about it, just fairly rigid foam rubber glued to the latch.
  7. RugerRedhawk
    RugerRedhawk Member
    113
    Jul 17, 2015
    Thanks for the pic, that's the type of pad I am talking about. Jayco gave me a starcraft part number 0196430, but they will not sell it to me and have directed me to my closest dealer which is an hour away.... Anyone with tips for a generic material that they've used for this would be helpful.
  8. jwrigley
    jwrigley Member
    58
    May 21, 2008
    alton, Il
    RugerRedhawk likes this.
  9. RugerRedhawk
    RugerRedhawk Member
    113
    Jul 17, 2015
  10. bheff
    bheff Well-Known Member
    1,055
    529
    Feb 24, 2011
    NW Arkansas
    I would just get creative and head to the local hardware store. Surely they have something that will work.
