Peel off "wood" paper or paint over???
Discussion in 'General Camping Discussion Forum' started by Ecyla1492, Apr 8, 2020.
  1. Ecyla1492
    Ecyla1492 New Member
    Apr 8, 2020
    I'm ready to do some painting, but I'm not sure how to prepare. Should I peel ALL the wood paper off or just paint over all of it? I assume it will look weird with such large pieces missing. Other suggestions?
  2. Raycfe
    17,424
    2,984
    Is it smooth we’re the “paper” is missing? Usually it’s not. Removing the the paper may make it even worse. I would do a test spot to see how the paint soaks in and how it looks when it’s dry first.
  3. bheff
    bheff Well-Known Member
    1,504
    928
    Feb 24, 2011
    NW Arkansas
    It may absorb the paint and swell!
  4. tombiasi
    6,380
    1,942
    I wouldn't even think about painting over paper. It needs to be removed. Wall paper remover or steam and then sand the wood, prime and paint. Why do it Half Fast.
  5. firepit
    firepit Well-Known Member
    2,038
    3,076
    Feb 26, 2020
    Nebraska Go Big Red
    Personally i would start with new cabinets...Anywhere that the particle/fiberboard is exposed will soak up the paint
    and dry flat and you will end up with dry dull spots next to shiny spots on the rest.
    Paint will not hold up on the spots you haven't touched....Remember a pop up is a small space and things get bumped into and
    kicked.
    Cabinets would not be all that expensive and with virtually no camping right now you will have time.
    jacinda and BBQdave like this.
  6. Anthony Hitchings
    2,431
    1,358
    Mar 2, 2019
    Oakland, California
    don't replace them unless you feel that you need to. There are easy paint solutions. I would try "soaking" off the fake wood paper with a damp sponge.. BTW - blue masking tape tends to peel it right off (*which really p....d me off at the time).
  7. Arlyn Aronson
    Arlyn Aronson Well-Known Member
    1,930
    1,492
    Jun 11, 2014
    Houghton, MI
    I don't believe that would be a "wall paper" in your camper. Its more likely a plastic covering that's glued on and not water soluble. Water does not do particle boards any good. You might want to sand it a bit and paint it. Personally, I'd call it a good ol camper and leave it.
    akriot likes this.
  8. BBQdave
    BBQdave Active Member
    260
    244
    Aug 31, 2016
    North Carolina
    +1
    If you have the time and this is a fun project, I would consider replacing the particle board cabinets with real wood cabinets :)
    Arlyn Aronson and James Rucker like this.
  9. Anthony Hitchings
    2,431
    1,358
    Mar 2, 2019
    Oakland, California
    Our fake wood feels like paper, but may be plastic. Its about one atom thick.
  10. Sjm9911
    9,317
    6,714
    You sre caught in a bad spot. And what people said is correct. The end game is what are you looking for? Spruced up or brand new? Peel back whats comming off. Leave the rest. Paint with an encapsulateing type primer. This should seal the paper and plastic coating. Spackle out the transitions and the paint it. Will it be perfect, no. It cant look worse. So i would try that.
    Ecyla1492 and Artist60164 like this.
  11. Old School Rob
    Old School Rob Member
    32
    39
    Jan 12, 2020
    Nevada
    Most Paper/plastic finish adhesive can be softened with a heat gun. Peel of the material, sand, prime, sand, then paint.
  12. tombiasi
    6,380
    1,942
    You are probably right about being vinyl "paper" in which case wall paper remover will do no good. I stand by the rest of what I said.
    I didn't see the pics when I posted, I thought it was PO installed.
    hammb likes this.
  13. firepit
    2,038
    3,076
    Feb 26, 2020
    Nebraska Go Big Red
    For the cost of paint and labor involved i would get new cabinets.
    One big bonus of that is you can put it back together and customize the best way
    that works for you...You may decide to go with less cabinets...More cabinets or somewhere in between.
    I cant see the floor real well but wood or laminate flooring wood be cheap and easy with cabinets removed.
  14. Sjm9911
    9,317
    6,714
    100 bucks worth of paint and like 6 hours over 2 days to paint it, or new cabinets. For some its a bit daunting installing cabinites. Ive done a lot of them( in homes), and to be honest, unless you build in place in the pup, i wouldn't do it. In fact i didn't. I painted mine. I didnt want to mess with the flip over galley and the cassette tolet and shower. And besides, most have time now. Its how much money do you want to put into it ,vs what its worth to you.
    kmbarreiros and Ecyla1492 like this.
  15. Ecyla1492
    Apr 8, 2020
  16. Ecyla1492
    Apr 8, 2020
    Despite popular opinion, this is the route I plan to take. I have been scraping any paper that comes off easily and then spackling transitions. I don't want to spend the time trying to get it all off. I bought an oil based primer sealer. Hopefully that'll do the trick!
  17. clif and sandra
    clif and sandra Member
    57
    45
    May 3, 2019
    We used Zinsser 123 oil based primer/ 2 coats, then sanded the damaged panels down to somewhat close to smooth, dry, then primed the damaged panels again, dry, light sand to smooth, then painted with 2 coats of gloss. We know where to look for the old damage but a visitor wouldn't likely be able to tell. Also, check your cabinet door measurements. you may find quite a few doors that are the same dimensions that would allow you to change their positions and put the worst doors in the least visible positions. All you would need to do is re-position the hardware.
  18. tenttrailer
    3,673
    601
    Jul 18, 2013
    Thornville, OH
    I would use eggshell paint. It's near flat, but can be washed. The higher the gloss the more the imperfections of the doors, wood grain and paper will be amplified by the paint.
  19. Sjm9911
    9,317
    6,714
    But the higher the gloss the more durable the paint is.
  20. tenttrailer
    3,673
    601
    Jul 18, 2013
    Thornville, OH
    That not correct, I use to think that. It's the quality of the paint and what application the paint is designed for that make the durable. Flat does not wash well but everything from eggshell to high gloss washes. I always check with a paint pro at sherwin williams, or if a big box store has a ex-painter in the paint department.
