Pine Sap
Discussion in 'Miscellaneous Repairs & Maintenance' started by nfisherman, Oct 25, 2015.
  1. nfisherman
    nfisherman Member
    320
    Apr 23, 2005
    Illinois
    Hi,
    Can anyone recommend a good product or method to clean pine sap from vinyl popup fabric?
    Thanks.
  2. jnc
    3,931
    1,190
    Oct 1, 2014
    South Central New Hampshire
    I would use good old PINE SOL.
  3. swordfish
    swordfish Well-Known Member
    2,218
    41
    Sep 27, 2010
  4. 3hooligans
    3hooligans Member
    629
    Jul 27, 2014
    Boston
    We have used rubbing alcohol, and alcohol wipes. A bit of elbow grease, but it works. Have to do my roof before we pack her away for the winter.
  5. adrianpglover
    adrianpglover Well-Known Member
    1,509
    36
    Jul 8, 2014
    Texas
    So rubbing alcohol is safe on vinyl tops? Having the same issue but with cypress sap and debris.
  6. jerry_ma
    jerry_ma Member
    735
    Oct 25, 2012
    Second the rubbing alcohol. I use it on the paint on my car, my clothes, etc.
    Jerry in MA
  7. tenttrailer
    3,572
    550
    Jul 18, 2013
    Thornville, OH
    On vinyl; I have used turpentine and then wash again with water and dawn to clean off the turpentine residue.
  8. 94-D2
    94-D2 Happy Campin'
    2,281
    139
    May 21, 2010
    Sutter Creek CA
    You can use a few things. Wd-40, works well On sap. It is however a patrolium disolate. Vinyl is a patrolium product. So wash it off with a good degreasing soap after like dawn dish soap. Another is mineral spirits. I used that to remove old caulking from my roof on the Coleman. I would stay away from alcohol, it removes all the oils and will eventually crack it, pine sol will clean it nice but leave the sap. Another thing you could use is silicone lubricant. It will also be good for the vinyls. If you are all homeopathic and such, peanut butter or salad oil works well too. Be careful with solvents that desolve the sap. It will also desolve vinyl. Oils like mineral spirits, vegetable and peanut, lessen the sticky properties of the sap and allow it to be removed. Sort of like gum in your kids hair. Wd40 etc break down the sap and allows removal. silicone is actually the active ingredient in Protectants like Armorall. But, use of that will eventually destroy plastics and vinyls over time.
    Good luck
  9. nfisherman
    nfisherman Member
    320
    Apr 23, 2005
    Illinois
    Thanks, all. We had a beautiful day here and I finally had some time to clean and winterize the PUP. I took jnc's suggestion because I happened to have some Pine Sol in the house. It worked like a charm. I mixed about a cup of Pine Sol in a gallon of hot water and wiped the fabric, leaving a liberal amount on the rag. I let it sit a few minutes and hosed it off with fresh water. The sap is gone. The whole process took about 1/2 hour. I'll be putting my spotless PUP in the garage as soon as the sun finishes drying the fabric. ;-)
  10. jnc
    3,931
    1,190
    Oct 1, 2014
    Sometimes the old way is the right way. I am glad it helped. The best part is the PUP now smells pine fresh and this will help keep the mice out.
