Pins for locking latches
Discussion in 'General Camping Discussion Forum' started by Rusty1778, Oct 18, 2019.
  1. Rusty1778
    Rusty1778 New Member
    Sep 20, 2019
    What do you use to keep the locking latches shut on a pop up camper? I'm restoring an old one and it had a couple of key rings in 2 of the latches and nothing on the other ones. Do you need anything? I'm thinking a small lynch pin or R-Pins? Photo below shows the style of latch.
  2. BikeNFish
    BikeNFish Well-Known Member
    2,922
    1,827
    Apr 24, 2017
    Maplewood, MN
    I use nothing. Never have.
    If I were to use something, I would probably just throw a small carabiner on it.
  3. Aladin Sane
    1,059
    97
    Jul 3, 2008
    Iowa
    Two of ours get small paddle locks.
  4. lksdrinker
    lksdrinker Active Member
    200
    46
    Oct 15, 2018
    You shouldn't need anything to keep them shut. You could use something to lock it there though.
  5. xxxapache
    2,881
    878
    My TT has six latches on the 3 storage areas around the belly. I use small pin clips.
  6. Snow
    10,137
    1,047
    Padlock..
  7. PopUpSteve
    PopUpSteve Administrator
    18,907
    1,644
    Dec 22, 2002
    Malvern, PA
    Those are there for padlocks. Most don't use them.
  8. Rusty1778
    Sep 20, 2019
    Thank you all for the answers!
  9. tfischer
    tfischer Well-Known Member
    3,528
    1,031
    May 21, 2014
    Carabiner
  10. Raycfe
    15,250
    1,453
    First off they are over center latches. When they are latched they will be tight. Second usually a pop up will only have one with an eye for a padlock.Just saying
  11. bheff
    bheff Well-Known Member
    887
    415
    Feb 24, 2011
    NW Arkansas
    Mine only has one that can be locked. The rest dont have the eyelets. I've never put anything in it to keep it locked.
  12. brwarrior
    brwarrior Active Member
    171
    73
    Mar 26, 2017
    Clovis, CA
    As others said I use a small padlock just so it doesn't come off. Not like it's going to stop anyone from getting in.
  13. campfire Joe
    campfire Joe Active Member
    172
    52
    Jan 27, 2015
    peru new york
    I don't use anything on mine either. AND for sure i wouldn't put a padlock on it, cause sure as heck i'd lose or forget where the key was!:eek::eek::eek::eek:
    Camper054 likes this.
  14. GreyFox
    GreyFox Well-Known Member
    1,407
    662
    Oct 10, 2018
    S Ontario
    Nylon cable tie(s). [A]
    theseus likes this.
  15. Snow
    10,137
    1,047
    I used a lock on the latch for when it was in storage and travelling, the key for it was kept on the trailer keys, so hard to loose it..
  16. WrkrBee
    WrkrBee Well-Known Member
    2,508
    960
    I keep a small Master padlock on ours. Locks are taped down to keep them from moving in the wind while towing. Locks are mainly to keep the latches adjustment from being changed. With the thick top seal on the Aliner, you can push down on the top and pop the hook off the latch easily with no need to unlock.
  17. Nancy Anne
    Nancy Anne New Member
    21
    Oct 9, 2018
    colorado
    We just use small zip ties and small pad locks. Just to keep the latches in the correct positions.
  18. Pnut
    Pnut Member
    76
    34
    Jul 8, 2018
    NE Georgia
    Cheap carabiner.
    jbirdt2001@yahoo.com likes this.
  19. theseus
    theseus Centerville, OH
    2,862
    411
    Feb 6, 2007
    Centerville, OH
    Zip ties. My palomino’s latches would come unlocked while driving. I would put a zip tie in the hole and they couldn’t come undone.
    The one on my front box I drilled out the hole to make it big enough to accept a standard Masterlock number 4 brass padlock.
  20. jbirdt2001@yahoo.com
    jbirdt2001@yahoo.com Active Member
    300
    27
    Aug 9, 2011
    North Dakota
    We use chain link with threaded closure on all four corners find them in hardware department
