Pittsburgh camping Family
Discussion in 'Introduce Yourself' started by Tz0604, Aug 2, 2020 at 2:48 PM.
  1. Tz0604
    Tz0604 New Member
    Jul 10, 2020
    Hello
    We are been tent campers for the past 15+ years and now have Acquired a 1990 Coleman Columbia!
    It’s a fixer upper with lots of travel under its belt.
    There are lots of holes, tires are junk, pretty gross overall but we will do our best to fix it up and not spend a fortune doing so.
    we had to find the lightest weight camper we could as we are towing with a 2011 CRV.
    here’s some before pictures.....
  2. nineoaks2004
    8,040
    3,583
    Dukes, Fl
    Welcome from Dukes FL. Good Luck with the NTU PUP and Happy Camping
  3. WrkrBee
    WrkrBee Well-Known Member
    3,839
    1,662
    Welcome to the Portal from South Carolina.
  4. megcabra
    megcabra Well-Known Member
    2,345
    602
    Aug 12, 2015
    Chapel Hill, North Carolina
    Welcome and greetings from North Carolina to the exciting world of Pop-Up camping!
  5. PopUpSteve
    PopUpSteve Administrator
    19,429
    2,081
    Dec 22, 2002
    Malvern, PA
    Welcome to PopUpPortal
  6. joet
    4,979
    1,063
    Welcome from the West Virginia mountains
  7. kcsa75
    kcsa75 Well-Known Member
    3,866
    1,974
    Sep 9, 2013
    Kansas City
    Greetings! Welcome to the forum from Midway USA.
    That doesn't look to bad. Nothing a little elbow grease can't fix. Good luck.
  8. bobinfleet
    bobinfleet Well-Known Member
    976
    400
    Sep 2, 2011
    Hampshire UK
    Hello and welcome from Hampshire UK[GBR], good luck doing it up and happy camping
  9. vagov
    vagov Well-Known Member
    4,432
    553
    Aug 13, 2012
    Pittsburgh, Pa
    Welcome from another Pittsburgher. (Brentwood). Fix er up to your liking. Then come join us at a rally sometime. Soon
  10. PA-Scott
    PA-Scott Active Member
    299
    130
    May 4, 2020
    Pennsylvania
    Hello and Welcome from central PA!
    You have an advantage you didn't realize, you get to make it the way you want to right from the start. You can alter it any way you want without feeling like "well it works so I shouldn't take that out"! If you don't plan on cooking inside you don't need a mounted stove, you can add what you want/where you want (basically) and have YOUR camper that fits you!
