Planning first boondock trip
Discussion in 'Boondocking' started by BillyMc, Jul 29, 2018.
  1. Arlyn Aronson
    Arlyn Aronson Well-Known Member
    1,214
    648
    Jun 11, 2014
    Houghton, MI
    OK I must ask, whats a "bed heater"? Spouse? Dogs? Do let us know! [LOL]
  2. gladecreekwy
    745
    846
    Sep 25, 2016
    Jackson Hole
    You’ll be fine.
  3. PaThacker
    PaThacker Well-Known Member
    1,205
    148
    Feb 11, 2010
    Poconos
    Depends on if girlfriend comes along or generator runs all night.
  4. BillyMc
    BillyMc Well-Known Member
    1,238
    595
    Mar 25, 2018
    Well just read a news report that a bridge on hwy 145 (goes through Sand Hills State Forest) has washed out due to flood waters from Hurricane Florence. There is multiple ways in and out, but going to have to keep watch on the news. Hoping I don't have to change plans.
  5. Nanapoppypops
    Nanapoppypops Member
    208
    Mar 30, 2019
    can you help me by telling me how, if you can, to charge my popup camper battery. I just bought the same one and would not be at an electric site. I would like to use this generator to charge the battery and am only interested in having lights, a little hot water. Not using air conditioning or fridge. Sure would appreciate. Thanks
  6. Nanapoppypops
    208
    Mar 30, 2019
    Wondering also, can I plug in the entire camper to this generator with an adapter and maybe be charging the battery this way?
  7. BikeNFish
    BikeNFish Well-Known Member
    3,010
    1,917
    Apr 24, 2017
    Maplewood, MN
    I have a 2000W Powerhorse generator. If your pup has the capability to charge your battery while hooked up to shore power, you can just plug your camper right into the genny and it will charge the battery while you take advantage of the rest of the power outlets to charge anything else that needs it (cell phones and such).
  8. Nanapoppypops
    208
    Mar 30, 2019
    That's the answer I was hoping for. I have the proper adapter for this but wouldn't mind knowing what you use. Thanks
  9. BikeNFish
    3,010
    1,917
    Apr 24, 2017
    Maplewood, MN
    My genny has the 30amp/120volt receptacle so I just needed an RV adapter plug, but you should be able to just use an adapter on your pup's power cord to hook into the 20amp/120 receptacle. See the pic below. The amp/volt plugs are shown in the picture if you aren't sure which is which.
    If you need to use one, make sure you get a heavy duty extension cord. At least a 12 gauge, 10 gauge is best, but expensive.
  10. BikeNFish
    3,010
    1,917
    Apr 24, 2017
    Maplewood, MN
    Free tip of the day - Make sure you run your genny down wind of the pup.
    brwarrior and neighbormike like this.
