PlastiDip for my A/C Shroud
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by thethird152, Sep 7, 2015.
  1. thethird152
    thethird152 Active Member
    621
    110
    Feb 1, 2015
    Mt Pleasant, MI
    Hey gang!
    I found myself with an extra day this weekend - nothing to do and feeling under the weather. I've discovered that, when I feel ill, if I can sweat like crazy it helps quite a bit in my recovery time.
    Well, it's still summer in NC, so sweating is no problem. I pulled the shroud off my A/C, ran to Lowe's, and started my project.
    The shroud was pretty dirty and grungy, so I hosed it off real well, then attacked it with some Windex and a scrub brush (seemed to work very well). Another good rinsing with the hose, then a once-over with some Acetone and it was ready for sanding.
    I used a drywall sanding sponge (medium grit) to remove any plastic burrs and rough up the surface a bit for paint. Another good round with acetone and I was ready to rock (and sweating like a pig).
    I decided to do the inside of the shroud first, in case I had any goof ups. Here are some pics:
    Before any work began:
    After a good scrubbing:
    First coat going on the interior:
    Second coat:
    Third coat (final coat for interior):
    First coat on exterior:
    That coat is outside drying right now - 2 to 3 more coats on the exterior, then a double coat of UV-protective clear coat and I think it's gonna look pretty sharp. Have some decals on order too that I think are going to make it look pretty awesome.
    Will post final pics when it's done, and a shopping list and price breakdown if anyone is interested.
  2. Shaun-Camper
    Shaun-Camper New Member
    34
    Mar 10, 2015
    I actually pulled mine off today too while repairing some cracks on the ABS roof. Note above I can't see your pictures.
  3. RotnMom
    RotnMom Am I there yet?
    4,125
    Apr 4, 2011
    thethird....make another post and just use the Attachment feature at the bottom left of the message box. Each post is limited to 4 pics, but you can make another post if you have more pics!!
    [:D]
  4. thethird152
    621
    110
    Feb 1, 2015
    Mt Pleasant, MI
    Oh sheesh - ok, sorry about that (I guess something changed and I wasn't aware :) ). Just applied the last coat of clear coat - will create a new post shortly with the before and after pics.
  5. thethird152
    621
    110
    Feb 1, 2015
    Mt Pleasant, MI
    Alright - here are the pics from earlier - hopefully in the same order :p
    photos 001 & 002
    photo 003
      File size:
      151 KB
      40
      File size:
      170.6 KB
      31
      File size:
      110.3 KB
      37
  6. thethird152
    621
    110
    Feb 1, 2015
    Mt Pleasant, MI
    photos 004 & 005
    Second coat:
    Photos 006 & 007
      File size:
      157.8 KB
      32
      File size:
      257.6 KB
      30
      File size:
      198.2 KB
      28
      File size:
      178.6 KB
      35
  7. thethird152
    621
    110
    Feb 1, 2015
    Mt Pleasant, MI
    Photos 008 & 009
    Photos 010 & 011
      File size:
      198.8 KB
      19
      File size:
      143.1 KB
      19
      File size:
      236.2 KB
      19
      File size:
      125.7 KB
      30
  8. thethird152
    621
    110
    Feb 1, 2015
    Mt Pleasant, MI
    Just had to pack it all up for the night. All in all I got about 5 good coats on the exterior, and 3 solid coats of clear coat. It took all day as you have to wait at least 30 minutes between coats, but it looks pretty nice.
    Two pics of the first pass with clear coat:
    Images 012 & 013
    Two that I just took a minute ago when I moved it into the garage to cure overnight (pardon my mess, we just moved in and there is stuff everywhere!):
    Images 014 & 015
    All in all a pretty fun project for a day off of work. I also stripped the heads on one of the bolts when I was removing the shroud so I bought stainless steel replacements for them. I bought a new said of phillips-head bolts as well as a set of hex head ones - going to try the hex head first but if they don't work our well I've got a backup.
    Hope everyone had a great weekend!
      File size:
      181.4 KB
      26
      File size:
      161 KB
      26
      File size:
      115.8 KB
      43
      File size:
      37 KB
      34
  9. Shaun-Camper
    34
    Mar 10, 2015
    Looks good. Here is my beginning cleanup. [​IMG][​IMG][​IMG]
