Plug in or Disconnect Battery at home
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by ce4, Apr 22, 2020.
  1. ce4
    ce4 New Member
    Apr 13, 2020
    missouri
    Currently have our pup in the driveway and trying to figure out what to do with the battery in between trips, planning another in a few weeks. I'm wanting to know, should I leave the battery hooked up and run our shore power cable, 30amp, to our house power using one of the 30ampF X 15ampM adapters, or should i just unplug the battery entirely, put inside and hook everything back within a few days of our next trip to charge it all?
  2. Raycfe
    16,433
    2,217
    YES ..... leave it plugged in with the battery connected. Ours is plugged in 9 months straight in a year.
    ce4 likes this.
  3. rabird
    6,882
    377
    N. TX
    disconnect and maintain (charge/check) every 1-3 months
    leave plugged in, verify battery voltage and compare to batt makers float voltage.
    Some folks are leery of maintainers 24/7 as they can act up.
    I use solar 24/7 which means it is mainly a maintainer but leaves interfere so I use a small smart charger from time to time.
    ce4 likes this.
  4. joet
    4,962
    1,056
    I unplug and use a Ctek maintainer/charger, which is kept on year round. The majority of the convertors don't do the best job of keeping a battery properly charged
    xxxapache and ce4 like this.
  5. bheff
    bheff Well-Known Member
    1,441
    831
    Feb 24, 2011
    NW Arkansas
    I pull my battery and keep it on a tender in the garage.
    ce4 likes this.
  6. ce4
    ce4 New Member
    Apr 13, 2020
    missouri
    Thanks for all the info! i'll keep it plugged in for now and test it from time to time to make sure the built in maintainer is working until i get a new trickle charger/tender. I tried using my normal charger/tender on it when we first got it and after 5 min, i was getting a real bad smell so unplugged that.
  7. WrkrBee
    WrkrBee Well-Known Member
    3,125
    1,298
    What was the smell and what was it coming from?
  8. ce4
    ce4 New Member
    Apr 13, 2020
    missouri
    It was a very acrid smell. Could not tell if it was coming from battery or the charger i had it on. I had the battery on some plastic leveling blocks but they were not hot or melted. The charger i use for my cars is a Schumacher SpeedCharge SC-1000A.
  9. xxxapache
    3,077
    1,069
    I would put a disconnect on the negative post, then disconnect after a trip and plug in to charge a day or so a month.
    Snow and ce4 like this.
  10. ce4
    ce4 New Member
    Apr 13, 2020
    missouri
  11. kcsa75
    kcsa75 Well-Known Member
    3,430
    1,698
    Sep 9, 2013
    Kansas City
    I disconnect the negative terminal whenever we put it in the storage shed (including all winter) and have never not had power.
  12. LaneG
    LaneG Member
    30
    17
    Wednesday
    50 Miles north of Seattle
  13. slowcarfast
    slowcarfast New Member
    19
    Nov 5, 2019
    Following. I'm also looking for a battery tender (or other brand) to keep battery/batteries topped off in between trips. I store the trailer in my garage so weatherproofing is not important. Currently have a single group 24 but looking to move to a pair of GC2s once I figure out a mounting solution (not sure how much size of the battery bank matters).
