Plugged into my home
Discussion in 'First Time & New Camper Owners' started by Mark Pierro, Feb 21, 2020.
  1. Mark Pierro
    Mark Pierro New Member
    Dec 30, 2019
    Hello-
    i plugged my N2M 99 starcraft (which needs lots of work) into my house with the proper dog boney thing. My lights worked. If I understand this correctly, that would mean my converter is working...correct? It converts ac to 12v dc, regardless if a battery is hooked up??
    I have the old battery but the inline fuse was pulled, so no battery was hooked up.
    Thanks
    mark
    rescamilla likes this.
  2. tombiasi
    5,528
    1,193
    If you got 12 Volt lights to light with no battery hooked up then the converter is working.
    rescamilla, xxxapache and Mark Pierro like this.
  3. Raycfe
    15,848
    1,836
    You are correct, your convertor is supplying 12 volt power. And as long as you don't have a switch on your convertor that's says CONV-OFF-BATT your convertor should charge your battery. Just an added note, don't leave a discharged battery out in freezing weather ....it will freeze and be junk. Usually the covers for the battery cells can come off ..... if yours do add distilled water until the plates inside are covered and get it charged and then tested. It may still be good, if you save it now.
    Mark Pierro likes this.
  4. roybraddy
    roybraddy Well-Known Member
    2,289
    829
    Mar 23, 2016
    King George, Virginia
    That is correct. However having a connected battery is a good idea as it loads the circuit down real nice... Also the battery is part of a required DOT Safety feature where a break away cable is used to lock down the trailer brakes if it becomes disconnected while being towed. This requirement is a DOT SAFETY feature. It is an Inspection item here in my State of Virginia...
    Here is a block diagram for a typical well organized 30A Trailer Inverter setup... Shows how the 120VAC and 12VDC circuits are connected around those two distribution panels...
    Google...
    Roy Ken
  5. Mark Pierro
    Dec 30, 2019
    thanks. Baby steps for me here. But I am stumped as wether or not the shore power will charge my battery while plugged in. I’ll get there. I need to be rebuilding the roof.
  6. WrkrBee
    WrkrBee Well-Known Member
    2,864
    1,147
    Check your battery voltage. Then plug the camper in. If the voltage goes up, the converter is charging the battery.
    rescamilla and Mark Pierro like this.
  7. MNTCamper
    MNTCamper Active Member
    946
    233
    Jun 14, 2014
    MN
    It likely will. There is a special circuit on the 12V side that is intended to connect to the battery and will charge the battery if it is connected. On newer converters, the voltage for the charge will actually vary on that circuit depending upon the mode of charging (how depleted the battery is).
  8. Mark Pierro
    Dec 30, 2019
    It’s probably been sitting for 8-10 years.
  9. Snow
    10,380
    1,205
    A 99 model year most likely won't charge the battery while plugged into shore power.. snap a picture of the converter and post it, or post the make and model of it ..
  10. xxxapache
    2,987
    977
    My TT is a 1995. It's converter charges the batteries.
  11. tombiasi
    5,528
    1,193
    I have the original converter in a 1998 and it charges the battery.
    Mark Pierro and xxxapache like this.
  12. Mark Pierro
    Dec 30, 2019
    Centrum 3000.
    Appreciate the help. Tossed a fly in there for fun!
  13. Econ
    Econ Well-Known Member
    658
    306
    Aug 18, 2019
    Deep South
    The battery is 8 to 10 years old?
    We'll now see how old you are
  14. FARfetched
    FARfetched Well-Known Member
    663
    318
    Nov 22, 2018
    Sector 706, Planet Georgia
    You can take the battery to any chain auto parts store to see if it's good. Just remember to disconnect it when you're not using it, because the converter and CO detector both continuously run when a battery is connected.
    And @Econ has reminded me just how old I am…
    Econ and Sjm9911 like this.
  15. Econ
    658
    306
    Aug 18, 2019
    Deep South
    Its nice to know I was not the only old goat that remembers DOA. Just relax and put the Lime in The Coconut.
    kcsa75 and Mark Pierro like this.
  16. GreyFox
    GreyFox Well-Known Member
    1,782
    881
    Oct 10, 2018
    S Ontario
    Repeated before on these forums but incorrect - the only time the converter draws power is when it's plugged into 120 vac shore power, when it's not it's effectively out of the system, is not drawing any power at all, and doesn't affect draw down on the battery.
  17. FARfetched
    663
    318
    Nov 22, 2018
    Quoting from the Starcraft manual, page 24:
    It might be incorrect, but the source is authoritative.
  18. GreyFox
    1,782
    881
    Oct 10, 2018
    S Ontario
    Figures - crappy Centurion converter. [:(O] Good thing the manufacturer went out of business. :p That said, every trailer should be wired with a battery disconnect switch which in every case would prevent parasitic draw down of the battery regardless of what's causing it. :D
    FARfetched and Snow like this.
  19. tombiasi
    5,528
    1,193
    By then I was married. Never listened to those kids anyway.
  20. WrkrBee
    2,864
    1,147
    Didn't listen to them then. Sure can't listen to them now.
