Poll, What should ny next camper project be?
Discussion in 'PopOut (Hybrids)' started by JimmyM, Apr 7, 2020.
What's my next project?
  1. Filtered water spigot on the countertop?
    13.3%
  2. Black tank flush system?
    30.0%
  3. Pull fridge to install condenser fans and interior fans mod?
    23.3%
  4. Replace CH751 locks with tubular type locks?
    3.3%
  5. Replace marker lights with LED lights?
    30.0%
  1. JimmyM
    JimmyM Well-Known Member Gold Supporting Member
    3,145
    1,128
    Jun 5, 2014
    Franklin, MA
    I found a page that had a map of states that allow/disallow it. Most eastern states prohibit it.
  2. bheff
    bheff Well-Known Member
    1,504
    930
    Feb 24, 2011
    NW Arkansas
    Maybe add a hot tub too!
  3. JimmyM
    3,145
    1,128
    Jun 5, 2014
    Franklin, MA
    I'll put that in the tiki-pup
  4. Sjm9911
    10,789
    8,166
    Like this?
  5. JimmyM
    3,145
    1,128
    Jun 5, 2014
    Franklin, MA
    Landing that helicopter on the roof must be a trick.
  6. JunieB
    JunieB Active Member
    331
    165
    May 8, 2018
    Central Florida
    MY Tiki Pup will be much prettier when finished! I got lotta Leis, signs already. Just have to haul out old sewing machine for valances, seat covers etc. Now giving it back to the original poster, No intent to hijack topic. Will show before & after eventually.
    Strawhouse likes this.
  7. Raycfe
    17,817
    3,296
    OK guys need suggestions. The marker lights on our camper are the standard 2 X 4 inch SignalStat lights with reflector lens. To replace the complete light with a good LED unit, these are my direct replacements (but no reflector lens)
    So I just replace all my marker lights, 11 of them (5 rear, 2 each side and 2 front) or find a "good" LED panel to modify my old ones.
    Do you like the clear instead of colored lens?
    Can you suggest a better looking DOT light?
    Can you suggest a good (more than 8 diode panel) to fit under the old lens.
    New lights are about 10 dollars each at a local NAPA store.
  8. JimmyM
    3,145
    1,128
    Jun 5, 2014
    Franklin, MA
    These are the Optronics units I'm going to use on mine. These have black "bodies", but a colored lens. They have ones with White bodies as well.
    You don't need a reflector with the LED types.
    https://www.amazon.com/dp/B07169Z7HD
    I prefer the colored lenses
    It would be great if there was a nice, low profile, regulated drop in panel for existing ones. But I haven't found any.
    The Optronics units are 3 LED, but I think you'll find that they work very well.
    I replaced my tail lights with Optronics LED units. I was a bit worried that they only had 2 LEDs. But they're brighter than the 3157 bulb types and clearly visible in direct sunlight. The 3157 units were garbage.
    I was thinking about doing the same thing you did (swapping the guts) for my tail lights. But found nearly direct replacements. So I went with that. Figuring I could always do the "gut swap" later if I was disappointed.
    The "gut swap" would be using a board I designed and built using a single under driven 10W red LED and my own controller. A 10W red LED driven at full spec is F*CKING BONKERS bright.
  9. Raycfe
    17,817
    3,296
    I have Bargman lights so they have a simple LED upgrade kit .... panel and new lens. Got all my reds on order, got a great deal. Still shopping for ambers.
    I did spend the 60 bucks for the factory Norcold 619020 fan kit. I know the thermo switch is usually about 13 dollars and a computer fan is cheap, but I just when for the factory kit. Maybe I will spend less time of the roof not having to make things up.
  10. JimmyM
    3,145
    1,128
    Jun 5, 2014
    Franklin, MA
    What retrofit kits? Do you have a link?
  11. pandpcamper
    pandpcamper Lifetime camper, newer to pup
    1,136
    Jun 25, 2012
    Join the Hybrid Travel trailer group on Facebook! Lots of great advice and kind people. Learn about the black tank system on You tube videos
  12. Sjm9911
    10,789
    8,166
    Facebook is not for everyone. Especially me.
    Ductape likes this.
  13. Raycfe
    17,817
    3,296
  14. JimmyM
    3,145
    1,128
    Jun 5, 2014
    Franklin, MA
    Thank you for the advice. But I'm not looking at "how" to do these. Just a fun thread about what to do next. I've already done a bunch of mods already.
  15. JimmyM
    3,145
    1,128
    Jun 5, 2014
    Franklin, MA
    I don't think they'll work on my camper. I thought they were internal boards that use the existing lens.
    I'll either have to replace the whole light itself or rely on those cheapie LED drop in bulbs. Which I'm averse to.
  16. Ductape
    Ductape Well-Known Member
    1,291
    314
    Jun 12, 2013
    I'm not trying to talk you into the cheap drop in bulbs, but for whatever it's worth.... in nearly five years, I think I've had one bulb fail.
  17. JimmyM
    3,145
    1,128
    Jun 5, 2014
    Franklin, MA
    That's pretty good. Yours must not be the "real" cheapies then.
  18. Strawhouse
    Strawhouse I miss my Camping Family... Gold Supporting Member
    1,796
    837
    Oct 4, 2015
    Muskoka, Ontario
    Nice one, Josh!:D
  19. JimmyM
    3,145
    1,128
    Jun 5, 2014
    Franklin, MA
    I did the filtered water spigot. I'm just waiting for a valve to arrive that will let me tap into the cold water line.
  20. AZcouple
    AZcouple New Member
    17
    Mar 5, 2018
    Show some pic's what you have done so far, we have a 2 bunk hybrid 20 yrs old, got it 3 years ago did some repairs needed to be done. Now our tub cracked may be due to never using it or just old. :-( I am thinking making curtains for by the dinette as gets so bright in mornings.
