Pop-up gizmos installed
Discussion in 'PopUp Gizmos' started by Neil0215, Aug 5, 2017.
  1. Neil0215
    Neil0215 New Member
    Aug 3, 2017
    Kentucky
    Installed the gizmos today and I have to say I'm impressed. Just sitting in my driveway in full sun, there's already a big temperature difference than without them. I had Bob sew on the velcro and I'm so glad I did. Went to Lowe's and picked up some industrial strength velcro and attached it just under the roof lip like many other have done so I can just leave them attached when we pop down.
    lynnmarie0123 likes this.
  2. Neil0215
    Neil0215 New Member
    Aug 3, 2017
    Kentucky
    Pics of the install
  3. Popiworks
    198
    66
    Jul 22, 2014
    They look really great! Nice install.
  4. Sneezer
    2,856
    1,689
    Looks good. I added hooks under the bunks and an assortment of rings and mini carabiners. Makes it so much easier to secure now. I was not impressed with the cheap plastic clips that came with them. I had 2 break after my 2nd trip using them.
    You may also need to reinforce the velcro you installed on the roof with some staples. On mine, at least in the hot Texas sun the velcro would start to come undone, so I ran some heavy gauge staples with a staple gun along the strip. No more issues. However - I don't think I used the industrial strength stuff, so you may not have to worry as much.
    One summer I added some pool noodles under the pugs, which helped insulate a little more on the bunks. This last summer I didn't use them and my AC struggled more to keep it cool in the afternoon. Granted I had no shade at that spot compared to the prior year. Only problem with the pool noodles is they take up a lot of room when packed. I am thinking I might get some reflectix and use a sheet under the pugs to help supplement the insulation.
  5. Neil0215
    Neil0215 New Member
    Aug 3, 2017
    Kentucky
    I used 3M automotive tape under the roof lip, and the velcro also had an adhesive backing. I'm thinking between the 2 adhesives...they're on for good! I also bought some reflectix and cut it to fit the bunk end windows.
    lynnmarie0123 and HappyTraveler like this.
  6. 1stpopup
    1stpopup Member
    256
    Aug 4, 2009
    SE US
    Looks good. I need to order for our new pup soon. One of the best investments we made on out 1st pup.
  7. fourhallatts
    fourhallatts Well-Known Member
    1,150
    461
    Jul 18, 2015
    North Syracuse, New York
    We added pool noodles around the bunk ends 2 seasons ago. My youngest ds said to me "Mom why don't we cut them in half so they are easier to store under the seats?" As they say "out of the mouths of babes" (though he was 15 at the time). They fit perfectly under the seats to store and they still work around the bunkends. I'm still mulling the gizmos since we may upgrade in a couple of years. We have been lucky when camping to get spots that were shady so the pup stays fairly comfortable.
  8. Wilkywoods
    Wilkywoods Member
    54
    Oct 20, 2017
    Indiana
  9. Wilkywoods
    Wilkywoods Member
    54
    Oct 20, 2017
    Indiana
    II'm trying to understand the install.. What's the pug? And the pool noodles serve what purpose?
  10. Sneezer
    2,856
    1,689
    Pop up gizmos. The pool noodles are placed between the canvas and the gizmo. It creates an air gap that further reduces the heat from the sun getting to the canvas.
  11. Wilkywoods
    Wilkywoods Member
    54
    Oct 20, 2017
    Indiana
  12. Wilkywoods
    Wilkywoods Member
    54
    Oct 20, 2017
    Indiana
    AAhh ok duh. the noodles are on the top then? Sorry, just hearing about these.. Sound like a must! We will be staying mostly at fairgrounds which have no trees!
  13. JBinNV
    JBinNV Member
    75
    34
    May 10, 2017
    Reno, NV
    Those are pretty cool !! I have the same exact PUP and they look good on there !
  14. Sneezer
    2,856
    1,689
    Yes - they go on the top, sandwiched between the gizmos and the canvas.
    The thing I don't like about them is they take up a lot of room for storage. If you don't strap them together they kind of go everywhere when you are trying to cram them into the aisle.
  15. CheapCampingComfort
    CheapCampingComfort New Member
    31
    Jul 22, 2019
    Virginia
    After realizing that our AC can only do so much in the heat, I just ordered a set of PUGs.
    And I will try the pool noddle idea when they arrive because I have a bunch just lying around in the garage.
    Thanks for the tip.
  16. Dan_Wyo
    Dan_Wyo New Member
    Jul 30, 2019
    Instead of Pool noodles would a blow-up pool rings work to provide the air gap? Uninflated they would take up very little space.
  17. lynnmarie0123
    lynnmarie0123 Active Member
    371
    80
    Jun 19, 2020
    can you explain where and how you place the pool noodles? are they glued down ? dont they shift around? how many are needed?
    Newbie from UT likes this.
