Pop Up Gizmos
Discussion in 'Canvas / Awnings / Add a Rooms / Tarps / Tents' started by jadenjdawg, Feb 9, 2017.
  1. jadenjdawg
    jadenjdawg New Member
    Jul 9, 2016
    I purchased a 1997 Dutchmen "Duck" back in the summer, and I am working on fixing a few things. The canvas is in decent shape, but appears to have some sun damage over both bunk ends. I believe the previous owners left it "popped up" for extended periods. The canvas above the bunk ends appears fine from the outside, but from the inside looks cracked. I sprayed some water-proofer on the inside, and I haven't really noticed any leaks. I was thinking about ordering a set of Pop-Up Gizmos to put over each end, but wanted everyone's thoughts? Also, the screen on the road side bunk ends are shot, apparently from sun-damage? The screen is fine every where else. Does anybody have any thoughts about fixing the screen? It looks like the entire screen needs replaced? It would be nice if some sort of glue would work? ANything to not have to sew?
  2. mrobuck
    mrobuck New Member
    18
    Feb 2, 2017
    You can always replace the canvas as well. I've looked into repairing or replacing our canvas before, and found this site. http://bearcreekcanvas.com/ seems pretty reasonable.
  3. sierrapup
    sierrapup Active Member
    373
    38
    Jun 19, 2016
    can't speak to the screen problem, but I can say that I absolutely love my gizmo's. [:D] summer or winter I never leave home without them... [8D]
  4. wecamp
    wecamp Member
    152
    Sep 28, 2006
    Grosse Pointe Park, Michigan
    We loved ours when we had the pup. Also used them. Kept the bunk ends cleaner.
  5. bknjohnson
    bknjohnson Tyngsboro MA
    397
    Apr 1, 2006
    Tyngsboro, MA
    The gizmos are great, really like ours, those are only going to cover the top of the bunkend, not the screens. I would not rely on them for weather protection because even with the high wind versions, it's always possible they will come loose in wind and rain. Recommend checking out www.canvasreplacements.com and bear creek as previously suggested. The can make just the bunkends for you, it is easy to install yourself and then you'll know that the canvas and the screens are all in good shape. We had to use canvasreplacements when critters destroyed our canvas one winter and they were fantastic to work with.
    nate1 likes this.
  6. RockyRoo
    6,592
    224
    Jun 8, 2012
    Loved my Gizmos, definitely get the super high wind versions, they won't go anywhere.
