Pop up portal and my anode
Discussion in 'Miscellaneous Repairs & Maintenance' started by Tom Jordan, Nov 2, 2019.
  1. Tom Jordan
    Tom Jordan Member
    67
    29
    Jun 3, 2019
    ArkLaTex
    One more reason for a neophyte to follow Pop Up Portal; I didn’t even know that I had an anode behind the drain plug. I think I’ll replace it now.....
    bheff likes this.
  2. Dan Wilson
    Dan Wilson Active Member
    176
    138
    Jan 30, 2019
    Appleton, WI
    Apparently you found an inch and a sixteenth socket in your tool box. I had to chase to two hardware stores.
    jmkay1 and bheff like this.
  3. bheff
    bheff Well-Known Member
    952
    462
    Feb 24, 2011
    NW Arkansas
    I'm weird and pull my anode after every trip. It rides just behind the WH door. I have one more year left on it still. I've heard of people using vinegar and then heating it to help remove all the scale that left inside the WH. Personally I think the flush wand works perfectly fine if you stay on top of the maintenance.
  4. Tom Jordan
    Tom Jordan Member
    67
    29
    Jun 3, 2019
    ArkLaTex
    Dan, I’m with you on that. I’ve made many of those parts store runs. Happily, the 1 1/16” trip was sometime in the past. I can’t remember, but that one might fit the steering wheel nut on an ‘89 Isuzu Pickup!
    kitphantom likes this.
  5. nineoaks2004
    7,382
    3,141
    Dukes, Fl
    Looks like it was time :) to replace it.
  6. joet
    4,761
    960
    When replacing the rod, Suburban recommends this. If on the end of your rod there is a weld nipple, its magnesium and it is to be replaced with an aluminum rod (smooth face) Switch the rods each on replacement.
  7. Tom Jordan
    Tom Jordan Member
    67
    29
    Jun 3, 2019
    ArkLaTex
    Thank you, joet, I appreciate the help. I had not found that particular piece of information, although I have found where Suburban suggests an Aluminium anode for highly reactive water sources (high in iron). I plan to stick with magnesium for another year just so I can monitor the deterioration.
