Popup bed supports
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by Rhconcepts, Jul 10, 2016.
  1. Rhconcepts
    Rhconcepts Active Member
    615
    100
    Oct 1, 2015
    Blaine MN
    This is a copy from my build log. I thought it would be best to post it here as well because not everyone would ever find it in my log.
    I'm the type that always goes bigger and better when I'm making things. Worried about the beds breaking with my weight I wanted to add support bars. I found bars at homedepot but they are to long and might not hold the weight. So here is what I did.
    First remove the rivet holding the foot on and cut the bars to the right size.
    Drill holes and bolt the foot back on
    Now they will fit under the bed. To make them hold more weight drill a hole at the top then raise the bar a inch and drill again through the same hole. When you drill a hole add a line on the top bar. When you jack up the bars stop at a line and place a pin or bolt through the hole. With the pin or bolt in, the bar will hold a lot more weight. This last part is not shown in the picture.
  2. Wrenchgear
    3,506
    753
    Aug 5, 2010
    5 Star Eagle Camper
    Do these bars go down to the ground or angle over to the bumper and tongue? What keeps them in place while the Pup is moving around from people walking around inside?
  3. nineoaks2004
    8,219
    3,678
    Dukes, Fl
    Good idea but It does not look too stable if they go to the ground movement can /will move them enough to fall, a dangerous position to be in if you are laying on the bed. If they are attached to the unit in some way they will be stable and not fall.
  4. Rhconcepts
    615
    100
    Oct 1, 2015
    Blaine MN
    Forgot to add this pic. If you close one notch at the end it keeps the bar from pulling apart.
    As for keeping them in place you take one or two metal spikes and drive them through the foot into the ground, under the bed im going to try a sheet of velcro. This is not my only support, im thinking it will help relieve some stress from the wall.
  5. Snow
    10,959
    1,618
    For awhile I used one of these (not cut down) as a secondary center support for the rear queen bunk on our Palomino... Worked ok, never had it "fall out" overnight but found it din't work on all campgrounds as no two sites have the same height from under the bunk to the ground.. Now use the bar in the back of the truck to help secure the sand bags in the winter ..
  6. Rhconcepts
    615
    100
    Oct 1, 2015
    Blaine MN
    So here I drilled holes like I said above. So if the ratchet part fails the pin will be in place.
    And this is the end that will attach to the bed. I bolted a block on the end and will have the bed and the bar connect using velcro. The bars pivot at each end so that will help when the beds move around.
    The only reason I made them shorter is so they would fit under the beds when im on level ground. Actually I went a few inches shorter than needed incase one end is closer to the ground. When I get out camping I will do a update on how well they worked.
  7. Rhconcepts
    615
    100
    Oct 1, 2015
    Blaine MN
    Well we tried them out :) first time camping and they worked great. They are only used as a secondary support and I didn't drive the nails into the ground. I jacked them up just a bit to put some tension on them and they never moved. I tried to shift the beds but the bars can pivot on both ends so they never moved. You can see them in the photo at the end of the beds.
    Sharkdude likes this.
  8. Rhconcepts
    615
    100
    Oct 1, 2015
    Blaine MN
    Update: I have been camping a few times and thought I would come back and give a update. The bars don't need the spike in the ground and they don't slide out. I have not even used the pins that I drilled the holes for and each bed can hold 2 people with no problems. I also think the wood blocks I made are way larger then needed so I might trim them down a bit someday.
    HappyTraveler likes this.
  9. Halford
    Halford Well-Known Member
    3,563
    569
    Sep 28, 2011
    Santa Clarita, California
    Don't you need to "lock" the bunkend from sliding back inside? That is the other purpose of pole support to keep the bunkend from sliding inside which could cause the shepherd hook bend or break. The shepherd hook is not designed to hold the bunkend in place. the anchor on the ceiling that hold the shepherd hook, might break off. The support pole serves this purpose to hold up the bunkend and to "lock" the bunkend in place.
    Your idea is wonderful but other factors has to be looked into, too.
  10. Rhconcepts
    615
    100
    Oct 1, 2015
    Blaine MN
    The original polls are still being used and do hold the beds in place. I just added my support poles as additional support because I heard of horror stories where people would be sleeping and the polls would break or bend and the walls would collapse making the bed fall.
    Kiddingaround likes this.
  11. Halford
    3,563
    569
    Sep 28, 2011
    Perfect...
    Dimples likes this.
  12. Fischymom
    Fischymom Active Member
    146
    49
    Jul 28, 2017
    Love this idea! I am going to look into this mod for our NTU PUP.
  13. Merlin14
    Merlin14 Active Member
    539
    60
    Aug 30, 2014
    I considered the load jack idea, but ended up cutting down a closet rod.
    It sets in front of the LP tank space on the tongue and rises to underneath the center of the front bunk which sags a bit.
    There's never been over 200# on the bunk overnight, as we sleep on other bunk.
    The distance between bunk where rod contacts plywood bunk and location where closet rod sits is fixed and rot can't move.
    I will be adding velcro to bunk and end of dowel to prevent slippage, which has to date not occurred.
  14. Carl & Theresa
    Carl & Theresa New Member
    Jul 14, 2018
    You know that is not only a great mod but a preventive mod if you all think about it all the weight on the ends have been known to give the frame flex causing the doors not to line properly. This could really help that issue be prevented.
  15. Jarius
    Jarius New Member
    Apr 27, 2018
    I did this myself as a precaution. One thing I did differently was to put the board under the foot touching ground. Get a little rain and that foot could sink up a bit.
  16. Rhconcepts
    615
    100
    Oct 1, 2015
    Blaine MN
    Smart idea Jarius. The campground we always went to was so packed the ground was like a rock but they could sink a bit. I never felt unsafe knowing I had the supports in. Would love to see photos of others that have tried it :)
