Popup jerks over bumps
Discussion in 'Tow Vehicles, Hitch & Towing' started by nairB, Jun 17, 2019.
  1. nairB
    nairB New Member
    May 31, 2013
    Hi there--I pull a 12' Coleman. With the old TV (Honda Odyssey) it pulled well, but jerked a bit (forward and backward, not side to side) when the road surface was bumpy (e.g., slab concrete). Now we have a Chev Traverse which is rated for more towing capacity, but the jerking is more pronounced over bumps. Both TVs pulled smoothly on smooth pavement. Any suggestions what I should check? Thanks in advance.
  2. nineoaks2004
    7,279
    3,022
    Dukes, Fl
    Check tongue weight, it should be 10 -15% weight on the tongue. Also check packing, heavier items should be toward the front, also would not hurt to get the tires balanced
    xxxapache likes this.
  3. Anthony Hitchings
    464
    157
    Mar 2, 2019
    is it being towed level?
    is the trailer suspension in the OEM configuration ( or has it been altered)?
  4. Sjm9911
    4,467
    2,285
    Well, when you hit a bump it bounces. How that equates over the diffrent tvs idk. It will jerk, front and back. I pull with a full size puck up , and it does the same. It depends on the bumps and pot holes and the grade its on. I would rhink that it would also be effected by the shocks on the tv. Better shocks, and newer ones could probably handle the bounce better. But thats only a guess.
    Minimalist and neighbormike like this.
  5. tombiasi
    5,311
    955
    That's what it feels like when you tow a trailer.
    Spridle likes this.
  6. Anthony Hitchings
    464
    157
    Mar 2, 2019
    Odd, I don't recall noticing jerks on our 2000+ mile long trip with the Aliner - even over the far back lumpy rocky dirt roads, whit I did hear is my sloppy ball mount rattling around in the receiver when on dirt roads.
  7. Ken Lane
    Ken Lane Active Member
    137
    76
    Apr 16, 2019
    Knoxville TN
    My Pup was tow bar was slapping quite a bit, particularly at low speed causing the TV to jerk from the impact. I added a collar that was recommended to me that I found on Amazon that cured the slap and subsequent jerking that I was feeling. It is called -
    CZC AUTO 2PCS Hitch Tightener
  8. Dudman5703
    Dudman5703 Jeep Guy
    278
    73
    Apr 17, 2012
    Grand Rapids, MI
    I technically only had the camper setup for my wrangler and not my SO's Jeep and she was towing it this past weekend and noticed it jumps around a bit more despite the fact it could tow much more than mine. Due to the suspension they do tend to jerk around a bit though, and it being on the correct level and the weight do matter. Though, like, they don't have shocks or anything so they don't ride as nice as cars do. Do you have more information for us to go off of - hey even a picture of the whole setup would help us help you.
  9. nairB
    nairB New Member
    May 31, 2013
    Thanks for all the replies. I will test the tongue weight probably tomorrow (today was devoted to cleaning and drying out!). The pup was close to level, but perhaps angled slightly up at the front--I had U-Haul flip an old hitch and ball so I can try a 4" drop instead of the 2" drop I was using on the weekend. Pup suspension is OEM. It doesn't really bounce--the feeling is that it tugs back on the TV. I've been looking at hitch tighteners (as mentioned by Ken) to try to take any bit of slack out, but haven't picked one up yet as I'll see what the other adjustments do first.
  10. davido
    davido Active Member
    876
    174
    Jul 17, 2014
    "It should be 10 - 15% of the weight of the trailer." -- fixed.
  11. mattlreese
    mattlreese Active Member
    208
    59
    Sep 6, 2017
    The local roads around my house have a lot of potholes and my pup jumps and jerks all over the place. However everywhere else it tows super smooth.
  12. Spridle
    Spridle Active Member
    847
    64
    Jun 6, 2011
    I can feel mine jerking around quite a bit back there even with a body on frame 3/4 ton truck. Just depends on the road surface. For sure I'd follow through and check the tongue weight and such, but at the end of the day these single axle trailers can move around quite a bit. My much heavier tandem axle open car trailer pulls much more smoothly than the pup does.
  13. tfischer
    tfischer Well-Known Member
    3,517
    1,024
    May 21, 2014
    Check your suspension. Our pup has a torsion axle and it was pretty much permanently bottomed out, made for a very rough ride on some roads. We just got it replaced this month... $$$'s but it now rides much much smoother, and we now also have trailer brakes.
    Spridle likes this.
  14. nairB
    nairB New Member
    May 31, 2013
    Thanks again. Tonight I checked the tongue weight...or at least tried! I was using a bathroom scale that goes up to 280 lbs.--the tongue would have surpassed that, so all I know is that it is at least 280 lbs. on the tongue. The trailer is about 2000 lbs. dry and has a GVWR around 3000. I don't fill the water tank, so I'm guessing load we are under 2500 lbs. Long story short, I think the tongue weight is okay. I haven't tried the 4" drop hitch yet, but have my hopes up.
