Porch Light Add-On?
Discussion in 'Lighting, Interior and Exterior' started by O'ville, Jul 26, 2019.
  1. O'ville
    O'ville Active Member
    213
    118
    Jun 24, 2019
    Dufferin County, Ontario Canada
    On my 2003 Coleman Utah the porch light has one of thoses powered "headphone jacks" the same as inside lights have that power my bunk fan/light. Besides the obvious in using the fan outside is there other attachments for this? Did Coleman/Fleetwood have a line of products that used these type of power connectors?
  2. Raycfe
    16,879
    2,478
    Our Coleman had one also ......... never used it.
  3. Sjm9911
    6,372
    3,723
    Im sure you can wire up any dc thing you want, maybe a fan? Mine doesn't have the jack.
  4. PopUpSteve
    PopUpSteve Administrator
    19,160
    1,931
    Dec 22, 2002
    Malvern, PA
    I don't recall ever seeing anything but the bunkend fan/lights but perhaps there were some after market items.
  5. Snow
    10,657
    1,400
    You can always take a creat-a-breeze or similar 12volt fan and wire it to work.
  6. jmkay1
    5,469
    2,255
    I don't know about anything provided by factory, but I use it with a bunk end light attached to a tarp pole so I can see when I cook outside. Works great for what I use it for. I tuck the tarp pole under the lip of the roof so it keeps it in place. I use a bungie to prevent it from slipping if it's windy. IMG_20190331_115625865.jpg
    Sjm9911 and O'ville like this.
  7. O'ville
    213
    118
    Jun 24, 2019
    That's a great idea. Will be replicating that for sure.
  8. GreyFox
    GreyFox Well-Known Member
    2,163
    1,092
    Oct 10, 2018
    S Ontario
    You can plug any 12 vdc device into this power source as long as draw is moderate, say 5 to 6 amps max. These "headphone jacks" are in fact 1/2" mono tip & sleeve audio connectors - tip is positive, sleeve is negative.
    Nothing other than bunk end lights / fans which were intended to be suspended from the shepherd's poles.
  9. lksdrinker
    lksdrinker Active Member
    210
    54
    Oct 15, 2018
    I believe there was something specific made for that port. I recall reading about something to be used in an add a room or screen enclosure. I think it was just another light that I assumed was very similar to the fan/light for the bunkend.
    Found it!.....its called a "portable light".
  10. O'ville
    213
    118
    Jun 24, 2019
    Nice! That would be a nice add on for in my add a room........ I knew there had to been something but chances of finding one of those though. [:(]
    I will use my bunk fan but I bet the cord was longer on that one.
  11. lksdrinker
    210
    54
    Oct 15, 2018
    Looks like this should work
    https://amzn.to/2K0Uco1
    O'ville likes this.
  12. O'ville
    213
    118
    Jun 24, 2019
    lksdrinker likes this.
  13. Snow
    10,657
    1,400
    You could always make on.. very easy...
