Portable AC solved after 4 years...I hope!
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by dannyv11, Mar 27, 2017.
  1. dannyv11
    dannyv11 Member
    245
    Jun 2, 2011
    Hi all,
    It's been a long time since I've posted anything. We started having kids a few years back and the pup was put to the side for a while (for good reason, I love my family)!
    I have a 1995 Fleetwood Coleman Utah and it is not capable of a roof AC without having reinforcement. Not to mention the cost of the unit itself. Add to that not really wanting to cut a hole in my roof. So I decided to buy a heavy and ugly used 10,000 BTU portable ac unit and I set it over my sink and let 'er rip in the summer.
    That means I don't have a sink or inside cooktop while I use the AC, which isn't a huge deal because we've got an adequate setup outside under the awning for cooking and cleaning. The AC drains into the sink and it vents outside at the bunk closest to it. I undo a few bungee hooks and lead the hose out that way. Maybe 3 feet of exhaust hose max is inside the pup, we haven't noticed much of a problem with the vent hose getting to hot or radiating heat.
    But, I want my kitchen counter back, with the AC on it, it takes up valuable real estate for storage and shelving...with a family of 5 we need all the space with can get. That and, it's a loud unit. I'd like to not have that right next to my head when I sleeping.
    So I came up with a plan. I'm going to put the AC unit under the rear bunk the protect it from the elements (hopefully) and vent the AC into the pup AND hopefully not look too bad.....but I doubt that.
    Here's what I came up with some far, and soon as we get a dry day, I'll set it up in the driveway and give it a test run, and post more pics.
    If this works for me, it will have only cost about $35 in materials (on top of the Portable units cost and some tools and hot glue sticks I already own)
    Let me know if you have questions, comments, suggestions, ridicules, or anything else.
    Above is the Portable units I own.
    I cut a hole the corect size and hot glued a container lid to the output on the unit.
    I then cut a hole the correct size and hot glued a larger container lid to the return on the unit.
    Then I cut 2 holes on the side of each container and hot glued these 3 inch vent hose connectors to the kids (1 output to each bunk and 1 input from each bunk)
    This is what the modified unit looks like through this evening.
    I have to install the 4" flexible vinyl duct next then cut everything to length. Place the unit under the rear bunk and test it out. I will hopefully post pictures of those steps soon.
    Thanks for reading!
    DannyV
    Haybale likes this.
  2. SteveP
    2,278
    947
    A truly unique and creative solution. I'll be waiting to read about how this works out.
    EDIT: Why did this turn up in my "New Posts" feed?
  3. noahnsteph
    noahnsteph New Member
    23
    Feb 21, 2005
    Definitely want to see the finished product and hear how it works.
  4. roybraddy
    roybraddy Well-Known Member
    2,394
    960
    Mar 23, 2016
    King George, Virginia
    Of course they already make roll around portable air conditioners with the same thing in mind...
    The problem being finding something that would fit the particular operating place...
    Google image
    I have on a few occasions brought along my small 5K BTU window unit which is very light weight and set in the unused tent bed area. Then fashioned the window flap material around using duck tap. This would run very easy off my 2KW portable generator. The water drain from it would run off onto the ground...
    Back in the tent camping days you would see one fitted up to a second tent door all sealed off with duct tape and sitting on a wood pallet.. Looks something like this
    Google Image
    Roy Ken
  5. Haybale
    2,551
    443
    Aug 22, 2013
    San Diego via MN
    That looks great, the only issue I see is the ducting may warm the air up quite a bit.
    I could see blowing the cold in one end and have the return from the other end. or blow the cold into the bunks and the return from the middle of the pup.
    I like the set up, it would be central air. Does the unit have a remote control?
  6. rocksncactus
    rocksncactus Member
    324
    May 10, 2013
    Cobb County, GA
    Just be sure to find a way to get it up off the ground in case of rain/rivers through the campsite.
    Years ago when a Tampa drive-in movie theater closed my brother-in-law bought an air conditioner from there. It was so hot and muggy in the summer that not only did you hook a speaker to your car window but you also hooked an air conditioner so you could watch the movie in comfort. He would hook the AC up to his boat through a window and set the unit on the dock; he did this on lobstering trips. One year we arrived in the Keys at the same time as he was leaving and he loaned us the AC to use while we were there. It was really hot and humid even by Keys standards that summer. We were tent camping at the time. We put the hose through one of the tent entrances and tightened the zipper around it. Wow! That AC only had one speed/temperature setting, full open, and with it on we were almost cold at night -- a nice change from the previous soggy nights where pillows were soaked with sweat, etc.
    At any rate, the second day a ranger appeared in the campsite and told us we couldn't have that unit sitting on the ground like that because when it rained there was a possibility of electrocution. Our solution? We set the AC in the rear of the pickup truck bed with the truck backed up as near the tent as possible. There was a Leer cap on the truck, so the unit stayed dry. Problem solved. But I always knew that ranger was probably right about the electrocution, so I've never forgotten about it.
  7. infernisdiem
    infernisdiem Member
    58
    Mar 24, 2017
    I would suggest something besides hot glue, it tends to breakdown when it gets wet (a few homemade RC boats taught me that), but it looks like you could use a dryer hose to feed the cold air into your camper, maybe even look at adding a pipe that feeds through an access door outside into the inside of your camper, when not in use, close the door, and you should be all set.
  8. Natureangel
    1,137
    356
    Feb 28, 2016
    Illinois
    Just FYI Gorilla glue makes glue sticks! I haven't tried them yet!
  9. mstrbill
    mstrbill Active Member
    696
    149
    Mar 17, 2013
    Austin , Texas
    They make glue sticks for different uses. I used a glue stick(for plastic) to seal the ballast tank(30 gal) on my daughter's basketball net for the last three or so years
  10. sawdusty
    sawdusty San Antonio
    866
    43
    Nov 9, 2014
    San Antonio
    That is great work. I am curious though, is it necessary to have the hoses to the return? I may not fully understand how these units work. Would it be possible to just open a window a little?
  11. Haybale
    2,551
    443
    Aug 22, 2013
    San Diego via MN
    Using the return would make it more efficient. That way it cools the air inside and recirculates it, vs cooling outside air.
    Just like using the recirculate option in most cars for the AC.
    sawdusty likes this.
  12. sawdusty
    866
    43
    Nov 9, 2014
    San Antonio
    Thanks! I did do some research and but your answer helped clarify. :)
    Haybale likes this.
  13. sierrapup
    sierrapup Active Member
    373
    38
    Jun 19, 2016
    interesting idea, perhaps some sort of bumper mount shelf to set it on
