Portable Solar Panel advice
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by Nephidoc, Apr 4, 2011.
  1. Nephidoc
    Nephidoc New Member
    Apr 14, 2009
    I'm headed off for the first trip in our new Baja.
    I wanted to augment our battery power with a solar panel.
    I'm using this as a learning opportunity. I know a smaller panel won't completely charge
    my battery. I don't want to fasten a panel to my new PUP. I also want a panel I can charge
    my ham radio battery with for field day.
    I have been thinking about the following prospects.
    Any advice, comments, detractions or plain heckling are invited.
    http://cgi.ebay.com/80W-Folding-Polycrystalline-SOLAR-PANEL-Portable-18V-/170621380327?pt=LH_DefaultDomain_0&hash=item27b9d3a6e7
    http://cgi.ebay.com/120W-Folding-Portable-solar-panel-w-s12V10A-controller-/270727273113?pt=LH_DefaultDomain_0&hash=item3f089a5a99
    http://www.amazon.com/Sunforce-50048-60-Watt-Solar-Charging/dp/B000CIADLG/ref=sr_1_44?ie=UTF8&qid=1301953567&sr=8-44
    Thanks for any help.
    Stan
  2. rabird
    6,922
    400
    N. TX
    That 80 watt panel ought to make 20 ah or more a sunny day.
    I estimate my max battery usage @ 10 ah/day or ~ three hours of furnace use.
    My single LED light only uses 1 ah in 7 hours so I don't count it [;)]
    Have fun with your education. I've never understood the angle the folding panels are set to.
    I've used this Solar radiation map.
  3. windstar
    windstar New Member
    90
    Aug 19, 2010
    .................. I've never understood the angle the folding panels are set to.
    I have learned from good sources that the angle of the panels should be equivalent to your latitude and and pointed to your true south.
    In my case:
    - true south is; 79W
    - latitude is: 43.4N
    don't use my numbers because i'm in canada, try to find yours and use mune as a reference.
    This way will give the best possible position to get the better of sun hours.
  4. bobhcs
    bobhcs Colorado Springs
    178
    Apr 13, 2008
    Colorado Springs
    I have an 85w panel which will keep the battery fully charged with about 4 hours of sunlight a day. I have all LED lights but use the furnace quite a bit. I made a spreadsheet to estimate my usage when I was choosing a panel and designed in quite a bit of margin for rainy days.
  5. ezduzit
    ezduzit New Member
    180
    May 10, 2010
    If I had the bucks, I would buy flexible solar panels. Generally, Solar cells are very fragile.
    http://www.siliconsolar.com/flexible-solar-panels.html
