Power Converter Trips GFI
Customer
2,435
Why do you believe the converter is the problem?
A GFCI trips due to an imbalance between the hot and common, it is doubtful that the converter would do that.
Harvardroger
If it feels good, do it! If it hurts, Stop!
Sep 5, 2011
576
On mine, I found that whoever wired up the converter hooked the neutral and ground wires to the wrong strip. Once I moved them the the correct strip in the converter, the problem was fixed.
Probably not a common occurrence, but wanted to through that out there.
Customer
2,435
Correct, the neutral and ground should not be bonded in the converter/power center which is treated as a sub panel.
