Power strip!
Discussion in 'Checkout My Rig !' started by Mdtim21219, May 1, 2021 at 3:11 PM.
  1. Mdtim21219
    Mdtim21219 New Member
    Saturday
    I recently installed this power strip and was wondering if anyone else was using it and what their experiences have been with it. upload_2021-5-1_15-10-58.jpeg
    Jwwiff likes this.
  2. NMroamer
    NMroamer Well-Known Member
    865
    591
    Apr 21, 2016
    Albuquerque NM
    Where did you get the power?
    It's crooked o_O
  3. jmkay1
    6,340
    3,247
    You know, that is a good place for it if your cabinet is anything like mine. I have 12v wires there I could easily access there and a pretty decent place for phones to sit. I’m kind of curious how accurate the battery monitor is. Please post when you get a chance to test it out. I have been thinking of putting something like what you have in, I just could figure out the best place to put it.
  4. kgibson
    kgibson Member
    57
    Mar 8, 2007
    I have the same one but haven't installed it yet. I'm planning on using the power by the radio and having the switch control the radio on/Off at the same time.
  5. generok
    3,104
    1,640
    Feb 7, 2013
    Anchorage, AK
    I've got a smaller one. Mine is accurate to within .05 volts according to my voltmeter. Good enough for me.
    Mdtim21219 likes this.
  6. Mdtim21219
    Saturday
    I tapped into the wires for the exterior light. Yes I know it is crooked or the extinguisher was mounted crooked. Bought mainly for a yearly off grid guys trip.
  7. Mdtim21219
    Saturday
    That’s a good idea about connecting through radio but might lose preset stations if power the stereo down.
  8. Mdtim21219
    Saturday
    The battery that came with the pop up is basically done for but planning on getting battery soon so I can test furnace’s ability to work off battery when off grid.
  9. Mdtim21219
    Saturday
    That’s good to know. I want to monitor how much the furnace draws down on the battery overnight over a few night to see when I have to replenish for generator.
  10. NMroamer
    865
    591
    Apr 21, 2016
    Albuquerque NM
    Check the fuse for the light. You might have limited power available.
  11. LilRed
    LilRed Active Member
    181
    94
    Jan 9, 2021
    Long Island NY
    I do like those setups! But… I opted for a basic 12v outlets, tapped radio feed and fridge feed and put inline ATC fuses lower than their branch fuses to ensure it didn’t blow their intended purpose. I didn’t want any parasitic drain from unused usb, meters, or other extra whatnot.
  12. David Blackwell
    David Blackwell Active Member Platinum Supporting Member
    111
    62
    May 10, 2017
    San Diego, CA
    I have a similar unit but without the on/off switch. I noticed that voltage display on my unit read 0.5 to .75 volts lower than actual. I'm pretty sure it has to do with the length/gauge of the wire run from my batteries to that outlet. Maybe 25 feet one way: Batteries on tongue, back to the WFCO converter wiring (a rats nest of wires), and then forward to the front wall where it's mounted. (I just did a quick estimate on a voltage drop calculator and it suggests that the voltage drop should be closer to 1.2v. I'll make a note to measure.)
  13. Turfit
    Turfit Member
    31
    33
    Dec 27, 2017
    Central Texas
    I just ordered one, planning to install it at the same general location and also tapping into the exterior light. But I am thinking about wiring it directly to the battery but that will be alot of work running wires......
  14. Mdtim21219
    Saturday
    It seems to be a nice setup. If you did decide to run it directly to battery, I do not think it would be extremely hard. I would just worry that you have to drill holes in the exterior walls or in bottom since you can’t follow current wiring since it goes to converter first then to battery. Let me know how it goes.
  15. Turfit
    Turfit Member
    31
    33
    Dec 27, 2017
    Central Texas
    My plan was to follow the current wiring even though it would take the long way around but I would not have any drilling to do.
  16. Mdtim21219
    Saturday
    Let me know how that works out.
  17. jeepster04
    jeepster04 Active Member
    150
    95
    Nov 23, 2010
