Powerwinch issue?
Discussion in 'Lift Systems' started by JeepinAndCampin, Jul 9, 2018.
  1. JeepinAndCampin
    JeepinAndCampin Member
    33
    Jun 6, 2017
    Salt Lake City, UT
    So i have a 2015 Palomino Basecamp 12FBS . It has the powerwinch P30001 for raising/lowering the pop up. 2 trips ago it wouldnt start to raise/lower unless i used the manual wrench to turn it a bit . now it just grunts a little and goes nowhere.
    does anyone know if you can replace parts of this or the whole? i need it repaired by wednesday night! i suspect best thing for me to do is replace the whole thing, but looking at options!
    any thing I'm not thinking of checking? its getting power as it makes an electric whine when i switch it up or down but no motor movement.
  2. BikeNFish
    BikeNFish Well-Known Member
    2,962
    1,873
    Apr 24, 2017
    Maplewood, MN
    I know this post won't help you, but power winches sure seem to be a pain in the arse. My power winch is so frickin' finicky that it doesn't want to work proper unless all of the stars are aligned and I have a four leaf clover in my back pocket.
    When mine eventually completely dies, I'm putting in a manual winch.
    JeepinAndCampin likes this.
  3. JPBar
    JPBar Well-Known Member
    1,870
    576
    Sep 22, 2016
    Texas
    When mine eventually completely dies, I'm putting in a manual winch.[/QUOTE]
    X2 ^^^
  4. JeepinAndCampin
    33
    Jun 6, 2017
    Salt Lake City, UT
    Well, Good news with an embarrassing twist :)
    I pulled up the owners manual for the winch and saw that there maybe a fuse to the setup... So i ran home to check that.. and remembered that I had bought some battery cleaner... removed the wires from the battery and cleaned up all the corrosion... AAAAND checked the water in the batteries... hmmm. I assumed that if the power was plugged up that the batteries wouldnt be an issue... Corrosion on the connections where the winch connected to the battery for the win! SO... just saved myself time, hassle and money of ordering a new winch setup expedited! WHEW.. Now once i get over the happy part, i face the embarrassment :) Thanks for listening to me not think this through... YAY
    JPBar and BikeNFish like this.
  5. DJS12354
    DJS12354 Well-Known Member
    1,566
    491
    Sep 21, 2017
    Glad to see that you found a solution. Thanks for sharing it, as it will surely help someone down the road.
